Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
Is is possible to purchase a battery cover for a D-535 Zoom camera? The small tags that hold the cover closed have broken and the batteries sometimes lose contact
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
You can order either the cover or just the shell from http://uscamera.com/d535.htm
Posted on Jul 08, 2010
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
D-535 zoom
try to remove the battery for an hour.. then put it back again.. then charge the battery at least 3hours..
Jun 27, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Broken battery cover.
I have a broken battery cover on my Olympus Camedia C-370 zoom digital camera.
Would you let me know, where I can obtain a replacement. I live in SW France.
Jan 08, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Lens Stuck Out/Will Not Go Back In
well u have a problem, and u will need to replace the mainboard. if it´s under warranty send it to the repair centre they will replace mainboard for free
Mar 01, 2007 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus C-370 LENS GOES OUT, IN AND SHUTS OFF
It is possible that a flexible circuit connector has loosened. This can be checked by removing the covers, DISCHARGING THE CAPACITOR. (The large, black, cylinder beside the lens.) Remove the black Phillips screws holding the LCD and main circuit board and then carefully lifting the circuit and checking the large connector on the back of the main circuit. BE CAREFUL! It is easy to break the flex. The other, most likely cause is the failure of the Photo Interrupter in the lens. The only solution is to replace the lens and reprogram the camera.
Sep 18, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
OlympusD535 zoom
It sounds like a silly question but are you putting the batteries in the right way round. I can't think of anything else which would stop them fitting. BMW
May 11, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
A/C adapter
There is an A/C adapter which is recommended for use with the D-535 Zoom Camera. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium at https://emporium.olympus.com/ or 1-800-201-7766. The Olympus stock number is 200751.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Battery life expectancy
The D-535Z uses two AA batteries, and Olympus includes alkalines in the box. Unfortunately those won't last long and will end up in the trash. So I recommend buying a four pack of NiMH rechargeables (plus a charger), which gives you a set for the camera plus a spare. Unfortunately Olympus doesn't publish any battery life statistics for the D-535, so I can't give you any exact numbers. It depends a lot on how much you use the flash and LCD screen. Don't leave the screen on all the time, use it sparingly and you should find an increase in shot numbers. BMW
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
