Question about Logitech Wireless Xbox GamePad Cordless Game Controller - 963279-0403
TDK DVD burner
Tray does not open. Green light burns steady. Thanks
  • Halderman Apr 19, 2008
    Thanks for your reply. I tried the paper clip but no luck. The clip goes in about 1 1/2 inches before it encounters resistance, then pushing does nothing. This is an internal TDK 440N burner.
    Thanks for your reply. I was able to open the tray by pushing on the long inserted paper clip. The tray came out slightly and then I was able to pull it out all the way. However, when I powered up the computer and booted up the tray did not retract. When I pushed the tray in with a loaded CD there was no response by the computer. Do I need a driver? My operating system is Fedora Core 5. I installed the burner myself. I've been trying to download a user's guide or manual but so far no luck.
Just try shuffling with the SATA ports and it'l be solved .... its not a driver issue ^_^
Posted on Mar 17, 2009
    Sergeant:
  • 202 Answers
Hello Halderman
Two possible things are happening.
(A) There is a program that has the DVD burner locked.
(B) It is mechanically stuck.
To open the DVD drive tray, please, follow these steps:
(1) Perform a normal shut down of your computer.
(2) Straighten out about half an inch or so of a thin metal paper clip.
(3) Look closely at the bezel (front face plate) of your DVD drive and find the tiny hole there. It'll be about the diameter of the tip of the paper clip.
(4) Insert the paper clip into the hole keeping it parallel to the floor or desk. (In other words, insert the paper clip straight in - not at an angle.)
(5) Slowly insert the paper clip into the hole and gently but firmly push in until the drawer latch is released. At this point, the drawer will pop open slightly. Slowly pull the drawer out to get the DVD or CD out. Be careful when pulling on the bezel. They are often held on by tiny plastic tabs that break off easily.
(6) S-l-o-w-l-y close the tray drawer or leave the drawer open. The drawer will close when the computer is turned back on again.
If you have ANY more questions, comments, observations, etc on this topic, please, post back here. We'll continue to work the problem w/ you until it is resolved.
If the information I provided here enabled you to resolve your problem....
...would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
Thank you once again for using FixYa! Have a beautiful day.
BJ @:)
Posted on Apr 18, 2008
  • 2 more comments
  • B Joan Rapier
    B Joan Rapier Apr 19, 2008
    Let's try a couple of other things:
    (7) Please, boot your computer into SAFE MODE. If you're unsure how to do this, please, visit THIS web site.
    (8) Once in SAFE MODE, open MY COMPUTER (usually by double-clicking on it)
    (9) **RIGHT** click on your DVD drive.
    (10) Choose EJECT from the resulting "context" menu
    (11) If this does not work, please, shut down (power off) your computer.
    (12) WHILE the computer is powered OFF, repeat the steps for ejecting the tray manually.
    A paper clip may not be strong enough for this device's eject mechanism. See if you can find an angled allen or similar that is long enough and thin enough to fit into the hole and use it instead.
    Some optical drives even come w/ an eject tool like I've described here.
  • B Joan Rapier
    My apologies, I didn't insert the link to the site I referenced.
    If you're unsure how to boot into SAFE MODE, please, visit THIS web site.
  • B Joan Rapier
    I've searched high and low for documentation on this burner.
    (13) Do you happen to have any documentation that it came w/?
    (14) Did you install it or did it come w/ your computer?
  • B Joan Rapier
    That's good you got it opened.
    B4 inserting another CD or DVD, make sure that you can eject and retract the tray using the front panel button(s). We want to rule out the possibility of this issue being caused by unreadable media.
    If you cannot get the tray to eject and retract using the front panel button(s) (w/ power applied), then the issue is not one of a driver for you Linux distribution OS. It is a mechanical or electrical problem w/ the drive. (I suspect the former.)
    As I said, I looked all over for documentation on this device and could find none
    Your only recourse is to return the drive or have it repaired. You can pop it in another desktop computer and see if the problem follows. I'm sure it will, though. But it won't hurt to try.
    If the drive never worked for you, then you may be able to get a warranty replacement. If, however, you've had it for a while, then you may be stuck. In that event, if it were mind, I'd pull of the front face plate and tray bezel and have a look inside. You may have a gear or belt that has jumped off it's track.
    Regarding the Helpful rating. Woud you mind terribly upgrading that to a "FixYa" as I did provide you w/ instructions for getting the tray open and for diagnosing the issue w/ your optical drive?
    I'd sure appreciate the generosity and show of appreciation. I'll be happy to continue to explore the issue w/ you, too. :)
    Thank you kindly,
    BJ @:)
Logitech gaming remote software
When you open the CD tray on your computer you should see a ring around the middle of the tray. The disc should fit perfectly into that space.
May 17, 2012 | Logitech Video Game Consoles & Games
How do i insert a small disk into my alienware pc? will it get stuck?
Hi bwhitm3
Your disk tray is made to hold the mini disc's is it about 10cm wide it sits in the middle of your disk tray if you have a closer look you will see a in dent in the tray where it would sit hope this information helps cheers nikki
Please rate my answer.Thanks for using FixYa.
Jan 15, 2011 | Logitech Dual Action for Pc (963292-0403:)...
I have acontroller, when i turn it on, it works
The lights are prolly just burn out. If it works then no problems
Mar 13, 2010 | Microsoft Xbox 360 Controller
Hp pavillion a350n green light on back blinks. after a power failure of three days my pc will not start. the pc was off before the power failure.
the green light blinking, is that near a network cable? It sounds as though the PSU has hung or had an issue. It might be worth trying to hold down the power button for around 20 seconds even 30 seconds. Then unplug the power and reconnect it. Try that and let me know.
Thanks
Mar 01, 2010 | Video Game Consoles & Games
My controller wont connect to my xbox 360 even tho i have my controller plugged into the concile
If this is a wired controller, it sounds like it may be broken and you'll have to call Microsoft and see if they can do anything about it. If it's a wireless controller that you're charging through the USB, you still have to synchronize the controller first. To sync the controller you need to press a circular button on the front of the 360 just under the DVD tray and the ring of light will start spinning. Next turn on the controller and then you press another small circular button next to where you plug the charger into the controller and the ring of light on the controller will spin. Once they connect to each other they will both blink and then light up to indicate which controller number the controller has been assigned.
Jul 18, 2009 | Microsoft Xbox 360 Controller
2 steady lights on a wired controller
me too. 2 steady lights on a wired controller. should we try and take it apart? i've havent found a solution online. im going to try and take it apart. wish me luck...
Sep 03, 2008 | Microsoft Xbox 360 Controller
X box 360 controller
Awesome...You are THE MAN!!! WORKS GREAT
Jul 21, 2008 | Microsoft Xbox 360 Controller
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Controller wont function
Try moving the xbox away from anything metal, most notably your TV, and then turn the xbox off. You may have to do the syncing again, but moving it away solves most people's problems.
Oct 27, 2007 | Microsoft Xbox 360 Controller
Logitech Wireless Xbox GamePad Cordless Game Controller - 963279-0403 Logo
176 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
