How do i turn off my microphone for the acer aspire 5920 series
    Novelist:
  • 150 Answers
The short answer is you probably don't, unless your laptop has a BIOS setting for it, which is unlikely.
I had a major privacy conflict with IBM/ Lenovo over that, bur there may be a work around:
1) Using the windows and/or audio card mixer program, e.g. windows volume control, find the microphone slide control and set it to minimum. Also enable the microphone mute button if there is one.
This is not 100%, but it will help, keeping in mind that rogue software can access and over-ride this setting at will.
2) Next, see if you're laptop has an external microphone jack. If it does, plug a short-circuited microphone plug into it. Make sure that the plug's short circuit wire is well soldered for best results. This should disable the internal microphone, and replace it with a dud. Be careful you don't stress and break the jack when handling the PC.
This will be quite effective, but again not a 100%, due to the huge dynamic range of modern audio cards and their ability to recover incredibly weak signals. A 16 bit audio card has a dynamic range of 96 decibels. a 24 bit card= 144 decibels. A 32 bit = 182 db. 1 bit = 6 decibels.
A shorted mic input may offer 100dB attenuation + another 48 db or so from the software volume/mixer control.
3) Finally you may try to totally uninstall the audio driver from windows, or to disable the audio card from BIOS. This will work, but you won't be able to play music either.
4) Another possibility is to physically destroy the internal mike,
look for a pinhole somewhere near your keyboard or display. Plug it up with glue. (Again a partial solution only)
5) There is a real security and privacy issue with laptops, because rogue programs (malware and trojans) can access the internal camera and microphone to spy on you over the internet,
broadband or wi-fi.
Cheers, Martin
Posted on Apr 18, 2008
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Hi, Meens here In my Acer Aspire 5920 Vista home preimum getting weird sound frm inbuild microphone after swtich on n the sounds stops after plugging headfons :(
The usual cause of microphone noise is caused by audio settings where the microphone gain may be turned up to high causing it to pick up noise from the computer or built in speakes. This can cause noise ranging from an odd hum to a high pitched squeal.
Check your sound setting first
Jul 12, 2009 | Acer Aspire One PC Notebook
Turn on internal microphones on acer aspire 5920
dont think it has a setting in the bios as to on or off. you didnt say what os you have on the machine. asuming it is xp navigate to control panel,sounds and audio you will find advanced button look and see if it's muted if so uncheck muted. next show volume icon on toolbar checked apply this. under the audio tab you can adjust the volume here also. next ime you can go to the same propertys page by clicking the spkr horn on the right side of the taskbar.
Jul 07, 2009 | AOpen Computers & Internet
How to turn-on/function mic in my acer aspire one pc notebook?
To test the microphone, click "start" button, then "Control Panel", then "Sounds and Audio Devices". On the popup window that opens, click on the "Voice" tab, then click on the button that says "Test Hardware". After several seconds this will bring up a test program that will show a noise level meter when you're speaking into the microphone. (The default device listed under voice recording should be "Realtek HD Audio Input".)
Jan 31, 2009 | Acer Aspire One PC Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 webcam doesn't work
Sir after formatting webcam and microphone need thier driver so please install webcam and microphone driver. I sure your problem will be solve.Thanks
Jethu Singh
Nov 26, 2008 | Acer Aspire 5100 Notebook
Getting microphone to work on an acer aspire 5920
go to the control pannel >sounds and audio devices > under the device volume click on advanced > and than the play control will open > click on option and than click on properties in the list there is an option that says microphone make sure it has a chk mark and if it doesnt have it put it there and than restart the system and than chk it
Nov 01, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5920 keyboard replacement
http://www.gadgetsmanual.com/aspire-5920-series-users-guide.html THat should be whatcha looking for. Good luck!!
Oct 15, 2008 | Acer Aspire 5920-6727 Notebook
How to download acer aspire 5920 sound drivers
http://support.acer-euro.com/drivers/ftp/ftp.html this is the site where you can download your drivers for Vista. since you didn't mention your OS I presume it's Vista.
Sep 08, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
