My Princeton VL1919 is working but the picture is blurry. Is there a driver I need to download? Or another fix? Thank you!
Did "Guest" (06/25/10) ever get a solution? I'm having the same problem. The graphics card is:
RAGE 128 PRO UltraGL AGP
Driver (per Device Mgr.) is "Plug & Play"
Should I update the graphics card or try to find a VL1919-compatible driver? From where?
Posted on Feb 28, 2011
Princeton vl 1918 monitor on screen it says check cable no signal. how do you obtain signal?
You need to verify to find out if it is the monitor is bad or the PC is not sending the video signal to the monitor. Try another monitor with the PC, if you still have the problem then you need to fix the PC, if it works OK then it is the monitor problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 08, 2010 | Princeton Digital VL1919 19" Monitor
Screen isn't coming on. I have a Princeton VL1919. The blue light blinks when on and the screen is just black. I have tried it on all 3 of my computers and it won't work. Any help would be awsome. Thanks
Common failure on the Princeton monitors are caps failure in the power supply, look for bad caps (bulging top or seal), see failed Princeton monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 26, 2010 | Princeton Digital VL1919 19" Monitor
Hello.Ihave a princeton vl1919 monitor.The problem is when you press the power button the light comes on for about a few seconds then goes out then you hear a tic tic ticing noise can i try and replace the...
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Feb 23, 2010 | Princeton Digital VL1919 19" Monitor
Princeton Monitor VL1919 won't turn on during boot up.
Try the monitor with another computer or with a laptop (as an external monitor). If it is working, the problem is related to the main unit. This case, have the main unit be checked by a professional.
Oct 04, 2009 | Princeton Digital VL1919 19" Monitor
Where can I find the driver for a Princeton VL1919 monitor
Princeton Graphics VL2018W monitor does not require any drivers to function. If you have problems changing resolutions, color depth, or refresh rates, Please consult your video card manufacturer for a video driver or support. Your system will not identify the monitor if video drivers is not installed properly. I agree with this statement. You dont need drivers for monitors 99.9% of the time. Usually you video card is what is wrong if u cant change the resolution.
Jun 05, 2009 | Princeton Digital VL1919 19" Monitor
Monitor dark for 20 minutes before turning on
My VL1919 has been having this issue off and on for a month or so now. It happened three times in one day today, so I decided to do something about it. I opened up the monitor and poked around a bit.
I found three electrolytic capacitors on the backlight inverter board were bulging, two of which had just started to leak: 71706a0.jpg The capacitors were placed directly above and next to a large, flat metal heat sink. I say above with respect to the flow of air due to convection, and next to because the heat sink also wraps around, enclosing the group of capacitors on one side. The heat sink sits flush with the circuit board, turning the board into a front enclosing face. When reassembled, the metal housing sits a fraction of an inch above the sink, forming a back face. This assembly is at the top edge of the circuit board, so the housing then takes a 90° bend to form a top face. These capacitors seem to get almost no air flow... Together with the heat coming off the sink, it appears the engineers have created their own little capacitor oven. Capacitors immediately adjacent to the affected components, but without blocked air flow looked completely normal. Looking at the traces on the circuit board and location of other components, the capacitors could have easily been moved out of the hot spot. This is either an act of gross negligence, or an intentionally created post-warranty failure point, designed to avoid market saturation. But that might be too pessimistic... "Never attribute to malice what can be adequately explained by incompetence." Anyway, I scavenged a few capacitors off an old computer power supply to replace the damaged parts (one 470uF 25V two 1000uF 10V capacitor, both rated to 105°C). To avoid a repeat performance, I soldered some short extension wires to the replacement caps and moved them out to an open area of the board, being careful to give the high voltage components plenty of breathing room. After reassembly, the monitor powered right up and came online. I guess the real question is how long it will stay this way.
Apr 05, 2008 | Princeton Digital VL1916 19" LCD Monitor
Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Jan 26, 2008 | Princeton Digital VL1916 19" LCD Monitor
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
