Question about Sanyo DP26746 26 in. LCD Television
Sanyo dp26648 26" lcd tv. Won't turn on. gives no indication of power. Had a power surge (electrical storm). Removed back (center panel) looking for fuse, saw nothing that I recognized and closed it up.
SOURCE: white screen
I called sanyo ,they had me try this and that and then said a tech guy would call back he did i am taking the tv to a repair shop and it will be fixd under the warranty.
Posted on Jan 13, 2009
  • 71 Answers
SOURCE: Manufacturer warranty for Sanyo 32" LCD TV
Refer to the user manual.
Posted on Mar 05, 2009
SOURCE: I need to hook up to digital cable
Thank you for your time.
I turned on the router supplied by Verizon, which I did not do yesterday, I'm embarrassed to say....
I called Sanyo and received step by step how to set up.
It was the same procedure I used yesterday with the exception of making sure the router was on,
I apologize for any inconvenience.
Reva L,
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: My Sanyo 26" LCD TV - model DP26648 has sound but only displays a
Turn off and on
Posted on Mar 11, 2010
budmrtn
  • 11361 Answers
SOURCE: 37' lcd sanyo. sound no picture. no backlight.
Check the lamps connectors on the backlight inverter board make sure they are not loose. You may be ahving failing inverter board itself.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 22, 2010
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
Who is liable for s replacement tv if electrical company turns power off and on during a storm and the tv won't come back on?
have you unpluged the power from the tv and the outlet for a few minutes? then plugged it back in?
Jul 25, 2011 | Sanyo Televison & Video
I have a 1 year old Sanyo Vizon HDTV and was watching a show when it suddenly just shut off and would not go back on again. No storms or any other power surges and it is hooked up to a real surge...
Hello
If there is no power indicator LED lights up when the set is sitched ON, the power regulator section inside your TV is faulty. There is a fuse [glass cartridge type]; on the power regulator board. If this fuse blows OFF the set won't switvh ON of the front power light won't light up. Check this fuse first. You can locate it at its power switching regulator board inside, where the AC power goes straight to it after a filternig circuit. If the fuse is blown out, replace ti with same rating. It ratings will be marked either on its edge rims of on its body by colour code lines. Replace the the fuse; if it has blown out, and switch ON the TV. if the replaced fuse also gets failed, do not put any fuse after, the power supply section has some short with it. It is best to replace the power supply board as a card absis; rather than making "surgery" to it. Some components in it will be very difficult to get too. You can buy a new power board from /Vizio Authorised Service Center at your town. OK.
Jul 14, 2011 | Televison & Video
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
We just had a lightning storm come through which knocked out the power. Once the power came on we tried turning on our sanyo LCD 24k40 tv it wouldn't come on. How do we fix it
I've checked on line for a schematic of this TV but was unsuccessful but I suspect it is one of two problems.
1) A fuse inside the TV was blown from a power surge caused by the storm. If you can locate it pull it out and look to see if it looks blackened (even a little) or if the wire inside is broken. This would indicate the fuse did it's job and stopped the power from burning out the whole TV. All of these fuses are available at your local electronics store or Radio Shack if you have one nearby.
2) The power supply on the TV was hit by the surge and burned out. There is no simple solution to this problem as the power supply would need to be replaced and the only way to do this is to hire a qualified TV repair service. If you happen to be good at soldering and understand electronics you could do this yourself after buying the power supply on line. I checked online and the part is about $60-70 USD.
There is a possibility that the power surge could have fried one of the circuit boards and if that's the case then you would have to weigh how much you want to pay to repair the unit after having a repair service estimate the work. I feel pretty strongly that you have one of the other two issues I listed since you didn't mention any other items in your home that were damaged at the same time. If there were more items then I would suspect the power surge would have been much more massive and likely caused considerable damage but since not then the damage would be minor leading to my previous conclusion.
May 23, 2011 | Sanyo DP46848 LCD TV
My Sanyo DP32648 was plugged into a surge suppressor and during a lightning storm the TV turned off. The DVD player, stereo and the clock are all working fine, and were still plugged into the same surge...
If you look at the power supply board as shown in the picture: http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sjdps153ap1a.jpg
There is a main fuse on the top left of the board covered by black shrink tubing, SLO-BLO 4A 250V. Check it out to see if it is blown.
Jul 27, 2010 | Sanyo DP32648 32 in. LCD TV
Sanyo LCD HDTV Model #DP26746
I am missing the stand to my Sanyo LCD TV. (DP 32647). I dont know where to buy a replacement one.
May 04, 2008 | Televison & Video
Sanyo DP26746 26 in. LCD Television Logo
222 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
