Question about Vacuums
How do you program an older night sentry timer model WT-341
I locked my comination code in the safe can you help bar code 3907400688 4 safe is MSW3517
Very sorry to know that you have lost the combination.
Well, the only way to get the combination is to contact Sentry and get it.
As per the company regulations, if you have registered the details of purchase and combination in their website then its very easy to recover, just send them the requisite information by clicking the link below, and they will forward you the combination.
Sentry.com
If you have not registered with them, then follow these instructions from Sentry:
First step, find the Model and Serial Number of your safe.
The Serial Number is in this packet, and is also printed on the small label beside the door hinge (outside). Send a copy of the model number and serial number of the safe, a notarized letter (last name of notary must be different than that of owner) stating you are the owner of the safe, and a check or money order for $12.00* (U.S. funds) to:
Sentry Group, Dept. 200,
882 Linden Avenue,
Rochester, NY 14625-2784 USA.
If using a credit card (Visa/Mastercard only), call 1-800-828-1438
and fax your Model and Serial number with the notarized letter
to 585-381-2940, 585-381-2940.
Next time make sure you record the combination and store it in a secure place such as a safety deposit box at your bank. Opening your safe could be a lot more fun, but never more simple!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 06, 2011 | Vacuums
Need to find a repair shop In Yuma AZ 85365, for an Estro Coffee Maker/Espresso Maker
here is a list of a few in Yuma that can fix your coffee maker.
1. M+S home appliance (928) 341-9792
2. Desert Sun appliance (928) 210-7151
3. Tony's appliance (928) 782-3235
c...
Feb 05, 2011 | Vacuums
GE 7 day timer 15091 set day and time and set programs correctly. Timer works right for several days then timer resets itself and loses time and programs. This is the third GE timer that I have...
1) If you have chronic problems with electronic timers, then circuit is suspect. Buy cheap circuit analyzer and plug into same outlet. Try timer on different outlet on different circuit breaker. Change Load (lamp, fan) to see if same problem occurs with different load.
2) Maximum load for GE 15091 is 600 watts incandescent. There is no HP rating, so timer probably not made for motor loads since motors draw high initial amperage. For heavier duty timer, with 1250W incandescent and 1/3 HP, select Woods 59201.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
3) I have tested GE timers. They are made well.
The 15091 is sold under different brand names, so it is successful design that's been around a while.
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 30, 2011 | Vacuums
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
I have a Model T25/2ED timer. Product #TN004000 I need to know how to program it?
I have the user instructions for the selecttime T25/2ED in Dutch and French in pdf format.
Contact me at andre.peeters3@telenet.be and I'll send it to you
Dec 28, 2010 | Vacuums
Need directions on how to program this outdoor timer, I lost the original instructions
Is this a vacuum system? If this is an outdoor timer for a Central Vacuum system, there will not be an outdoor timer, nor an indoor timer. If you are operating a ROBOT vacuum, there is a timer on the charger. Please explain.
Nov 16, 2010 | Vacuums
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
