Question about Xantrex Technology Xantrex XPower Power Inverter 400 Watt (456001) 400-Watt Power Supply
My sw3048 xantrex inverter inverts, but will not charge my batery
The inverter will transfer to grid power when there grid power but will not charge the batteries
ithana
  • 185 Answers
SOURCE: xantrex power inverter 1750
Sir ,
  one of the ic or resistor will be damaged inside ,so kindly replace it,it will be alright.
Posted on Sep 07, 2008
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Posted on Sep 08, 2009
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
Posted on May 21, 2010
SOURCE: the inverter dose not charge the batters on my coach.
From the manual I read on the Xantrex website shows 2 fuses. 1 in the F1 Position which is the outer circuit breaker, and the other in the F2 position. You can see the F1 tube-style fuse from the front, but the F2 fuse you have to tuck your head behind and see it from the other side. You can see if the fuse wire is burnt. To be sure, use an ohm meter to check the continuity of the circuit. Hope that helps.
Posted on Aug 18, 2010
SOURCE: Trace / Xantrex SW5548 inverter (one of two in a
Because it's made in CHINA!!!!
Posted on Jul 09, 2011
N manual to cover and remote
PDF]Owner's Manual Freedom Basic Remote Xantrex Freedom ...
www.xantrex.com/.../Freedom%20Basic%20Remote/Freedom%20Remot...
Freedom Inverter/Charger Remote Control Panel is not intended for use in .... n. Freedom charging. INVERT. O ff Invert function Off. Power Up Indications and Default V ... Xantrex covers both parts and labor necessary to repair the product, and ...
Product Information: Roamio Remote Control - TiVo
https://support.tivo.com/articles/Product.../Roamio-Remote-Control
TiVoAllow Pairing mode: This pairing mode is for manually adding a new remote control or transferring a remote control from one DVR to another. When you put the ...
[PDF]REMOTE CONTROL RC-N - Bernafon
Jan 01, 2016 | Televison & Video
Xantrex model rs2000. just purchased used. owner said all worked. got wired up, charger does not operate, shows no external power source, (led not lit). checked power to unit, at 119-123 acv.. inverter...
If it shows NO external source, then this is most likely the best place to look to find out why not?
http://www.ehow.com/how_7519715_troubleshooting-ac-inverter.html
Now above is a link that show you how to troubleshoot an AC inverter. Now below, there is a service manual, here at the back, is a factory troubleshooting chart that will be beneficial to you.
www.xantrex.biz/...Inverters/.../XS400_Owner_Guide(975-0054-01-01_Rev- B).pdf
The Biggest problems with Inverters is Flat/Low/Bad batteries, Sometimes it pays to remove the batteries and charge then up remotely, and then replace them, fully charged, Now a fully charged 12 volt battery should have 13.8 V DC at the terminals with NO LOAD. If the battery only reads 12 V it is not properly charged.
Dec 20, 2010 | Xantrex Technology Xantrex RS2000 Sine...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
Inverter seems to be working but batteries aren't
is the bateries draining quikly?, if so try redusing the load on the inverter ,always make sure it is fully charged before use.
Feb 08, 2010 | Xantrex Technology Heart Freedom 25...
Heart 2500 w charger inverter only shows shut down and will not start bateries are new why
if it does not start, the inverter control or power transistors that do the switching may be bad
Jun 05, 2009 | Xantrex Technology Heart Freedom 25...
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Xantrex XPower Power Inverter 400 Watt (456001) 400-Watt Power Supply Logo
56 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
