Question about KDS Radius RAD-9 (Black) 19 in. Flat Panel LCD Monitor
I'm looking for schematics for a kds Rad-9 AX191 to see where to connect the 5v power. Power plug is missing and too many wires are attached.
4 Suggested Answers
SOURCE: KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Posted on Jul 24, 2008
SOURCE: KDS Rad-9p wont stay on
my monitor will not work it will come on when the pc is cut on but it will not display
Posted on Sep 02, 2008
budmrtn
  • 11361 Answers
SOURCE: What power supply do I use for my kds rad-7bk?
No! the current capacity way too low. check here:
http://shop.ebay.com/sis.html?_kw=KDS+RAD-5+LCD+Monitor+AC+Adapter
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 22, 2010
KDS Rad-7c struck by lightning
try to use another monitor power cord if is can turn on, otherwise immediately contact your monitor manufacturer to repair such device since it was struck by lightning
Dec 06, 2011 | KDS Radius RAD-7 17" Flat Panel LCD...
My KDS-50A2020 TV has an error code indicating a lamp driver fault (5 red blinks). I replaced both the lamp and the ballast and it still doesn't work. I need further assistance troubleshooting the...
Hello.
Ballast in Sony is one of the most reliable parts, almost never goes bad.
I assume you have TV unplugged from the wall outlet to reset error memory (not to mention that you have to do it anyway during ballast replacement).
I hope you are using good quality lamp, because cheap substitute from E-Bay can cause same problem. Lamp and ballast works as duo and on-board diagnostic system is unable to separate them unless lamp is completely blown (in that case you will have steady "Lamp" LED blinking).
You need to set TV up with back cover removed but lamp door attached (there is switch that prevent TV from working if lamp door is removed). You need to locate large 2-wire connector on ballast and make sure that it's getting about 330V DC from power supply board when you turning your TV on. If it's not there - you have power supply board problem. There should be fuse on it (not on the ballast board but power supply board - just trace those two thick wires where they coming from). That fuse could be blown by previous bad ballast shortage.
Small connector on ballast have 5 pins. Some of them ground, one of them steady 5V and another trigger (turn on signal) 5V. Make sure all voltages are there. If there is no trigger 5V - you have problem with main board.
In my experience 90% cases - it is very bad quality new lamp or something is just not connected (forgot to put plug all the way or something).
Russ.
Aug 17, 2010 | Sony KDS-50A2020 Television
Monitor doesn't work
If you look at the monitor's video cable, you should see a little pigtail coming off of it with a round connector. There is a power supply that attaches to that which in turn plugs into the wall. If you have lost it, you might be able to get one used someplace.
Sep 09, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Aug 24, 2008 | KDS Radius RAD-9p 19" Flat Panel LCD...
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
KDS Radius RAD-9 (Black) 19 in. Flat Panel LCD Monitor Logo
214 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
