Question about Black & Decker Dewalt #D55155 2HP 4GAL Eleccompressor
Dewalt D55155-QS 220 volts can it convert to use 115 volts?
I just brought a used Dewalt D55155-QS, but not realize this compressor use 220 volts. Can I convert the motor to use 115 volts?
  • tqpham Jul 08, 2010
    Thank you very much.
  • 4,234 Answers
The short answer unfortunately is no. The internal motor that drives this compressor requires 220 and will not work properly with 110. Your only option would be to replace the motor with one compatible with 110. The cost of that would approximate a major portion of a replacement unit.
Sorry about the bad news.
Dan
Posted on Jul 08, 2010
How much oil does the Dewalt emglo d55155 air compressor use?
Without knowing the exact model number, it looks like 4 oz. You can buy here for less than $6.00.
Bostitch CAP2000P OF Air Compressor Parts
May 27, 2017 | Dewalt Air Tools & Compressors
Dewalt d55155 compressor runs to 60 lbs then acts like not enough power and shuts down
Looks like it's an oiled style compressor. Is it getting pretty hot by the time it hits 60psi? Might be low on oil, or the oil has been contaminated with water from condensation. If that's the case then what is happening is the compressor is causing too much resistance for the motor to turn it because of the excess friction. This is could be what is causing it to shut down prematurely.
Nov 23, 2012 | Dewalt D55155 Emglo Air Compressor
I'm using my dewalt for bead blasting projects, Lately moisture is coming from the pistol
It's on the bottom, right hand side of the tank if you are facing the tank side. You can download the owners manual from this link. It is at the upper right side of the page in the section marked downloads.
DeWalt D55155 parts and owners manuals
Aug 21, 2012 | Dewalt D55155 Emglo Air Compressor
I want to convert my compressor from 115 V to 220volt? There is nothing in the owners manual on how to do this. Can you help me?
Your garage mate unit was made to operate on 120 volts. That one reason there is nothing in the owners manual. To convert it my be costly.First your electric motor must be able to handle 220 volts. you will need to look on the motor tag and see if it has 120v/230v. if not you will have to purchase a new motor that will handle 220/230 volts.If your motor will handle 220/230/volts you need to look at the the wiring diagram attached to the motor. you then will need to purchase a 220 v plug and outlet and correct wire size to install.
Jun 21, 2011 | Ingersoll Rand - Rand 2 - hp 24 - gallon...
Dewalt emglo d55155 air compressor-what type of oil? this machine is electric
Need to use air compressor oil it is available at you local hardware store in the tools department.
Feb 05, 2011 | Dewalt d55151 factory reconditioned emglo...
I want to change my EMGLO D55155 compressor oil. What type and how much oil should I use? Thank you!
The compressor tanks 4 ounces of oil.
You want to use a synthetic oil in this unit. We like to use Mobil 1 full synthetic 10w30 oil.
Here is a link top the owners manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55155/D55155_OM.pdf
Oct 07, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
How many watts does it have?
Watts is calculated by multiplying voltage times Amps. Locate the specification tag on the compressor for Amps For example 120 volts times 10 amps equals 1200 Watts.
Aug 20, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Dewalt/Emglo D55155 compressor screeching and breaker blown
Sounds like it isn't getting oil on the bearings. Take it apart yourself,after you get a diagram of it and find a parts source.
Mar 22, 2010 | Black & Decker Dewalt #D55155 2HP 4GAL...
Singer 7422 power output
The electrical specifications are as follows:
220 - 230 V
50/60Hz
Total 65W
Regards
Enjoy your machine
Dec 04, 2007 | Singer 7422
Black & Decker Dewalt #D55155 2HP 4GAL Eleccompressor Logo
230 people viewed this question
Top Black & Decker Air Tools & Compressors Experts
John Trevino
Richard Schanie ...
Tom Chichester
Are you a Black & Decker Air Tool and Compressor Expert? Answer questions, earn points and help others
