Sanyo PLC XU35 Multimedia Projector Logo
Posted on Jul 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We are having one sanyo plc xu 78 projector.when it began to switch it on the count down screen will displays when the count down timing is coming to 0 then its directly going to stand by mode. its not going for starting page..... what is the reason for that........pls help me
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Jul 08, 2010
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563145
Points
12312
The countdown shows while the unit is going through its internal circuit testing. Usually if a problem is found, there will be indications with the standby lights and lamp/temp lights. Are there any other indications here or just the unit going into standby?
Dan
Sanyo plc xu 22e,i get the red lamp indicator and the ready inicator but then the fans turn off and nothing happens. i can see the lcd through the lens and it displays sanyo and starts to count down from...
1,the lamp and the ballast is ok
2,it seems the motherboard is broken.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
QUERO COMPRAR A LAMPADA PARA O PROJ. SANYO PLC XU 100 BARROSO 86-9981-2684
USD140,the Original lamp
have a nice day!
1helpful
2answers
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
1helpful
No way to get simultaneoulsy my videos on the laptop monitor and on tne projector PLC XU 73 card : ATI Radeon X700
Most laptops have a Function (Fn) key in an alternate color (blue maybe) from the usual key text color (white usually).
By pressing this key, along with another key that has text of the same (blue) color, perhaps labelled with "LCD/CRT" or a pic of a monitor, or of 2 squares - one single square and one double "square in square", you can toggle between the modes of:
1. Laptop display only,
2. external display only, or
3. Both displays.
Be sure to check your laptop model manual for specific details to make sure this is possible.
2answers
Sanyo PLC-XU86/83 Usb cable Problem
Hi there
It might be that you are using the port for this function.
I suspect that you are using the one on the side of the unit - instead of the smaller usb port at the back - which is actually the one that should be used for this function.
The USB port on the side is made for a flashdrive.
2answers
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Top Sanyo Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
