Question about Plumbing
Lefroy brooks cartridge
How to remove thermostatic valve cartridge from lefroy brooks GD8700 shower
3 Suggested Answers
  • 5 Answers
SOURCE: replaced moen 2225 cartridge leaks when valve is turned on
is this the single handle model? if so simply remove handle, plate, then pull the clip out with a pair of needle nose (after turning main water off).
the valve assembly will pull staright out with moderate force. sounds like one of the small o rings got pinched so it may take a good pull.
make sure to look inside valve housing for foriegn debre. clean it out good. i like to turn the water on for a few seconds before i put the new valve in to blow out any stuff that might cause problems.
Posted on Mar 14, 2009
SOURCE: how do I remove the handle on a Grohmix thermostat
Pop off the little round plate that's on the front face of the handle. Under that, there's a screw that you can unscrew and then the handle comes off.
...jon
Posted on Dec 19, 2009
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
Lefroy Brooks flush valve
Most flush valves are universal, but try to contact manufacturer and see if they can help, or try plumbing supply store (not a home depot)
Jun 21, 2013 | Lefroy Brooks Plumbing
How do I change a hansgrohe thermostatic shower cartridge
Different valves have different techniques for replacing thermostatic cartridges. Without knowing specific model numbers I cannot give accurate instructions for the procedure. If you need help identifying the valve feel free to contact me at Hansgrohe Technical. 1-800-334-0455. press 2 for tech and ask for David Scarborough. I'd be happy to help.
Aug 30, 2012 | Hansgrohe Home
Flow rate on delta thermostatic valve
the two screws are service stops open them all the way
Jun 09, 2012 | Delta & Single Handle Shower Faucet
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Bath waste
    ! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
    Good luck and thanks for rating my effort.....the Fang.
    Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
    Plumbing Logo
    320 people viewed this question
    Top Plumbing Experts
    Andrew Bugbee
    Tom Chichester
    Gil Shultz
    Are you a Plumbing Expert? Answer questions, earn points and help others
