Question about Samsung SCX-4216F All-In-One Laser Printer
MR COMPUG WHEN IT START TO PRINT OR COPY GIVE ME :: LSU ERROR
  • 161 Answers
LSU is "Laser Scanner Unit". It can be expensive to replace, and your unit is discontinued.
Posted on May 29, 2008
The printer shows LSU error, When i Turn it of after 2 or more hour I can print max 3 copies and then the same error appier (LSU error).
Hello my friend this is Laser Scanner Unit error and this is probably cause if the polygon motor in the LSU does not rotate.The LSU’s laser beam is
functioning properly.You can try unplugging the machine for 3 minutes and plugging back in before you do anything else.If this does not fix it you will need to have it serviced.
Feb 03, 2010 | Samsung Office Equipment & Supplies
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Sep 16, 2008 | Office Equipment & Supplies
PROBLEM PRINTING
LSU = "Laser Scanner Unit". It can be quite expensive to repair and the unit is discontinued.
Apr 18, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Blank papers comes when the print given
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Feb 03, 2008 | Samsung ML-3051ND Laser Printer
LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Jan 02, 2008 | Dell 1600n All-In-One Laser Printer
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Problem with copy
LSU Error is showing the printer and is in non working condition
Nov 09, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
37 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
