Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Spinning debris in cup
My debris is not spinning in the cup and there is no suction, and the hoses are getting clogged
  • caramel2k49 Jun 24, 2008
    I've had the same problem and can't find any clogged areas that would explain the loss of suction. Still looking for a solution.
  • 328 Answers
If the 2 stage filters inside the bin chamber have not been washed then they will need to be - they sound like they are clogged or somewhere there is dirt which is blocking up the system. Also check the side part duster to ensure that the airways are not clogged with dirt.
When you turn the machine on, have a look to see if the moving brush is actually spinning. Then switch off and remove the base plate to see if anything is clogged in the main dirt channel which is usually located on the left or right hand side - where the dirt goes in from the floor.
This model is based on an Electrolux model in the UK which can be notorious for clogging dust. Check the hoses at the bottom where they come from the main dust bin and the air ways to check no dust is stuck.
Posted on Apr 19, 2008
Why is it not sucking up
Hi, it's Jim with Crucial Vacuum!
I'm unsure as to the specific make and model of your vacuum, but general loss of suction can be improved with these maintenance tips. After completing these checks you'll notice a difference in your vacuums performance.
First thing to check is the brush roll and belt. If the brush roll isn't spinning try rotating it manually to help unclog any hidden debris. Your vacuums belt stretches out overtime and lessens in tension. Make sure your vacuums belt is on your brush roll nice and tight. Without these two parts functioning properly your vacuum will have poor, or no suction at all.
Empty your units dust cup, or change out the bag if necessary. When you allow dust and debris to sit in your vacuum it leads to clogs throughout your unit. Avoid this by changing out your dust cup after every use.
Another area to check for clogs, which may be effecting your vacuums suction is the hose. Stretch out your hose fully to see if any debris are stuck. If there are any clogs that are hard to reach use a broom handle to unblock it.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 09, 2015 | Vacuums
Why I have no suction
If your vacuum is lacking in overall suction there are several places you can check to help your vacuum operate at its peak performance.
Jim Thompson
Mar 04, 2015 | Vacuums
Vacuum not sucking up debris.
HI, it's Jim from Crucial Vacuum!
Here are some general vacuum maintenance tips that will help out with your Oreck vacuums loss of suction. After applying these solutions you should see an improvement in your vacuums suction.
Lets check out your brush roll. Look for any noticeable debris, and be sure to manually rotate the brush roll to unearth any hidden clogs. If you see carpet fibers, or strands of hair remove these with a razor.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction.
Another area to check is your vacuums hose. Stretch it out as far as you can to see of any clogs. If there is a clog in a hard to reach spot try using a broom handle to unclog it.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight.
You can purchase replacement parts for your Oreck direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=oreck&limit=all
Jim Thompson
Feb 14, 2015 | Oreck Vacuums
What causes poor suction on model ud40270? It seems like a lot of air is blowing out the front where the filter is.
Susan:
First, remove and clean or replace all of the filters in the machine. There is an inlet filter above the dirt collection cup. and an exhaust filter at the front lower part of the top of the vacuum head. If either filter is clogged, you'll get poor suction. Also lay the machine on it's back, and check the tunnel where the dirt goes up into the machine (behind the beater bar) to see that it is not clogged.
Jan 08, 2015 | Filter Vacuums
Beater brush stuck on (keeps turning) in upright position and no hose suction with Hoover U5753-900 WindTunnel Bagless Upright Vacuum. I have tried adjusting the brush level up and down and moving the...
Your Hoover may be losing suction in the hose and having an issue with the brush roll due to a clog within the vacuum, or possible debris stuck on the brush roll itself. Here's some tips that will help.
First off, if your brush roll just keeps turning be sure to turn off your vacuum before examining it. In regards to the lack of suction in the hose there may be a clog in the vacuum itself.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction, for the hose as well.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Lets look at the hose itself. Stretch the hose out entirely to see if there are any clogs within. A handy way to unclog your hose is to use a broom handle or coat hanger. Make sure the coat hanger is a plastic one. You don't want to tear the walls of your hose.
As for the brush roll itself. Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. Also, manually spin the brush roll to see if there are any clogs or debris stuck within.
You can purchase replacement parts for your Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+windtunnel&limit=all
Jim Thompson
Dec 14, 2014 | Vacuums
I have Bissell Powerforce Bagless Upright Vacuum. it doesn't suction well. I checked the belt. It is ok. may be clog in the hose.I don't no how to clean. can you help me please?
- Check the dirt cup to make sure it is empty.
- Your vacuum has 3 filters. Dirty filters will restrict air flow. The filters may be hand washed in cold water with mild detergent. Allow them to completely dry prior to reinstalling them. The white HEPA media post-motor filter is not washable.
- Lift the upholstery hose from the bottom holder. Check for suction at the end of the hose.
If there IS good suction at the end of the hose, please unplug your machine from the outlet and try the following:
- Ensure the hose is firmly pressed into the lower hose outlet on the back of the vacuum.
- Check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum. Check the belt and clean the roller of dirt and debris.
- Check the lower hose for clogs by removing the screw which attaches it and lifting the hose up to clean it out. Also, remove the larger hose by twisting it off and using a broomstick handle, push any dirt and debris through the hose.
Aug 05, 2010 | Bissell Vacuums
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
Eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Oct 03, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
99 people viewed this question
Top Eureka Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
