When i turn on my computer sometmes i get nothing on y monitor n sometimes it white i can hear the fan running
Cpu no on
Posted on Jul 08, 2010
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
My compaq fs7600 monitor wont turn on
Hook a spare monitor to the computer, if no change! the Video Graphics Card is suspect usually built into the motherboard. But if spare shows picture, the problem lies in the HP monitor, as a last resort change the video cord from the computer to the monitor "if possible" to rule out something simple.
Mar 15, 2012 | HP Compaq FS7600 17" CRT Monitor
Computer comes on but nothing show on monitor u can hear the fan but nothing show on the monitor
  1. Make sure that your monitor cable is plugged into the back of the computer, also sometimes depending on the setup of your computer there can be 2 places to plug you monitor into on the motherboard, if you see another port that looks the same try plugging it into that one and try again.
Feb 15, 2011 | Compaq Presario 5WV270 (202498-003) PC...
When I turn my computer on the monitor does nothing, i also see power to the keyboard, but when i enter a ctrl/alt/del command the dower lights do not change, indicating working in the background.
Can you hear the Power supply fan running in the back of the computer? Usually, these symptoms indicate a faulty power supply to the motherboard. When was the last time the fan was cleaned?
Sep 25, 2010 | Dell E228WFP LCD Monitor
When I turn on my monitor, its goes straight to a
  • when you turn on computer. after sometime your monitor goes to standby mode and monitor light colour will be orange it means problem with your computer not monitor.
  • After this You Check your VGA Card.
  • When you turn on computer is there any beep.
  • After this also check your RAM.
  • May be problem with your RAM.
Try this Technique .
Mar 13, 2010 | HP w1907 LCD Monitor
Signal has gone
If the monitor comes on and displays a message like "no input signal" or something similar, it's working properly but there is nothing coming from the computer. People often think that the computer is working and the monitor is at fault, when in fact the computer isn't starting up.
When you turn on the computer, do you hear the normal sounds of the power supply fan running and the hard drive spinning? Most computers will give a beep when they turn on and the motherboard finishes some startup checks. Do you hear that? Do you ever hear the normal startup sounds that mean Windows is actually running?
If you are convinced the computer is starting and booting into Windows, I would suggest you borrow a known good monitor to use as a test. If it works, that obviously means yours is bad. In most cases there's nothing you can do to repair a monitor yourself beyond checking for loose connections, bent pins in the signal cable plug, or a damaged cable.
If a known good monitor still has no image, the computer is at fault. Either the video card or integrated video isn't working, or the computer isn't actually starting up. In any case, that's where you would need to start looking for the cause.
Hope this helps you along the way to solving the problem. Thanks fo using Fixya!
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Light on monitor is green when turned on, but then turns orange with nothing on the screen. I can hear the computer running though.
your monitor is not recieving a video signal from your pc. check your connection to pc, then check things like bad memory card, etc. sometimes just shut pc on and off a few times clears this up.
Jun 03, 2009 | Computers & Internet
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Fan
No reply
Can't help without details, sorry
Apr 16, 2008 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
Computers & Internet Logo
David Payne
David Payne
