Question about Craftsman Mechanics Air Tool Kit Impact Wrench/ratchet
Why doesn't my craftsman air sockets not fit craftsman impact wrench tight?imapact has no pins for sockets to stay on?is there something I need to impact for them to stay on?
  • 253 Answers
Make sure the expansion ring is on the end of the impact gun. this holds the sockets in place.
Posted on Aug 10, 2010
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
How do you oil a Craftsman Air Impact Wrench Model No. 87518846
If you are just oiling the gun,hold it upside down and squirt some oil ine the air chuck fitting.(I just use an empty bottle of my wife's hair dye filled with ATF-it's cheaper than a can of "air tool oil".If you are referring to the grease fitting for the impact mechanism,look for a small hole with a captured metal ball.The only tool I found to fill this is a specially designed miniature grease gun(got mine at Sears).
Jun 13, 2012 | Craftsman 3/8 in. Pistol Grip Impact...
Craftsman 1/2 inch air impact wrench i bought one and i don't see a chuck in the box nor do i see instructions on how to attach sockets....i've never had one before and don't want to sound like an idiot,...
  • There are no chucks with these newer impact wrenches. See that little ring on the tip of the socket shaft? That is a lock ring and that is what holds your sockets in place. You will want to keep a few 1/2 impact wrench lock rings around. There is a tool they make to aid in removing and replacing those rings but it is not necessary. You can use a small flathead screwdriver and walk the old one off and the same for replacing it. All you need to do is snap a socket on there real good and let'er rip.
Regards, Tony
Apr 23, 2011 | Craftsman 1/2" Impact Wrench
Leaks air from handle
is air fitting in tight with pipe tape? has a gasket started leaking? may be an oring on something screwed inthe bottom is loose or broken.
Sep 02, 2010 | Ingersoll Rand (IRT2115TIMAX) 38" Drive...
What sockets fit
Any sockets will fit the ratchet, 3/8 drive, the impact drive is 1/2 drive, and they make hardened sockets for it. And I can't really make out the last tool there in the kit. The impact tool will take normal sockets for reg duty use but not for wheel lugs and such, they will crack, but if you buy Craftsman, they will replace it. I have only cracked one in thirty years. But I also have the hardened set of sockets. Hope this helps.
Jun 25, 2010 | Craftsman Mechanics Air Tool Kit Impact...
Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Apr 29, 2010 | Craftsman 1/2" Impact Wrench
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
My impact wrench wont engage to the socket.
I have the same problem, brand new impact wrench, brand new impact sockets, but can't get a socket onto the gun. Leaned on it with all my weight, wiggled, nothing. and yes they are both 1/2" drive. WTH?
Nov 21, 2009 | Craftsman 1/2" Impact Wrench
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
1/2 air impact wrench will not turn socket. Air just comes out the small vents on the bottom of the handle. Any suggestions?
Make sure the fitting are tight on the hose and gun. Also make sure that the switch for forward/reverse is solidly in one position, if it is not it will cause what you described.
Jul 09, 2009 | Craftsman Tools 1/2" Air Impact Wrench...
Craftsman Mechanics Air Tool Kit Impact Wrench/ratchet Logo
446 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
