Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon ip3000 printer keep saying that front cover closed whereas it is open and of course it wont print
  • c_trooper Jul 08, 2010
    just couldnt see any switch, please show,
    thanks
  • Canon Master
  • 6,826 Answers
Check for a bad switch/sensor for the front cover.
Make sure you close it tight.
Posted on Jul 08, 2010
  • Duane Wong
    Duane Wong Jul 08, 2010
    Sorry, I don't have the picture, but if you go on to the website for the printer and get an exploded parts view, it might be there.
    good luck.
Dell 924 all in one cover open
Sounds like the sensor for the cover is not working. If you open the cover when it is on, then close it, does the error remain? It only needs a microscopic amount between 'open' and 'closed' - check if there could be a tiny bit of paper somewhere around the edges.
Failing that, get in touch with Canon.
May 17, 2014 | Canon PIXMA MP830 All-In-One InkJet...
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
How can I remove the Canon iP3000 ink jet printed heads for cleaning?
heres the support site for that printer http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238 - downloads and drivers tab - has all the software and user manuals - the FAQ tab has a section on cleaning the printhead using software - also a link to removing the printhead
The FAQ has full images and step by step instructions Remove the print head iP3000
  3. Note: Gently open the paper output tray while holding it.
  4. After confirming that the print head holder has moved to the center, open the inner cover. Remove all ink tanks.
  5. Raise the print head lock lever and remove the print head.
  6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  8. Close the inner cover and top cover.
  9. Note: Check that each ink tank is installed in the correct position.
Apr 10, 2010 | Office Equipment & Supplies
My canon inkjet pixma ip3000 says it has no paper when it has. It has worked before but now it just says paper out when i try to print.
this i think is simple. you put the paper on wrong. it sometimes happens to me on me printer. look at your operating manuel to see how to properly put on the paper
Oct 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I need help with installing ink
Open the front cover when the printer is turned on, wait until the ink tanks move to the change position. push the clip on front of each tank in and lift the tank up. take the tape off the new tank cartridge if it has one (only if it says to remove it) put the cartridge in and press down until it clips. close the front cover and the ink will return to its normal place and initialize
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
The power button is blinking six orange and then one long green. What does this mean. My printer won't print black at all. Have done all cleans and changed the cartridge but won't print any pages with...
According to the product manual, six flashes of orange indicates an Inner Cover Error. The manual says to close the inner cover and then press the RESUME/CANCEL button.
Mar 24, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma ip3000 flashing amber 6 times
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Jan 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
May 19, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
114 people viewed this question
old marine
old marine
