Question about Maytag MMC5000 Microwave Oven
Samsung Pro Gourmet works but doesn't work
I found your 2006 post about Microwaves that do everything they're suppose to (lights, timers, turntables, etc) but don't heat anything. Well, I got it bad I guess. I guess I'm not alone when I admit that we open the door without hitting stop all the time to check on stuff and we recently changed the over-range-bulbs without unplugging from AC. I'm not intimidated with electronics and don't mind doing a bit of trouble shooting myself. It's probably cheaper to replace a couple parts than to find and tote this thing to a good technician like yourself. You mentioned a couple links on your website but I couldn't find your website. Can I get some further direction from you so I can check out some of your referenced documents?
Sincerely, Bruce in Atlanta
  • Maytag Master
  • 9,098 Answers
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 20, 2008
  • William Miller
    William Miller May 09, 2008
    Did that solution merit a "FixYa"rating?
Is there an easy fix for a microwave that does not heat?
There is a separate fuse for the magnetron. Usually inside the case. The magnetron is the part that makes microwaves. The door switch could also be the culprit.
Aug 04, 2014 | GE Spacemaker 1.8 cu. ft. Over the...
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
Frigidaire microwave fmv156dcc
There could be an open fuse inside or a failed magnetron.
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Our sharp r520lw just quit working, timer works, light works, all buttons work, (clear, etc) however turntable doesn't work and no
That would be a bad bottom door switch or its mount.
See the help file on door switches here.
See the service manual here.
Dec 13, 2011 | Sharp R-520LW Microwave Oven
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
http://www.gallawa.com/microtech/mag_test.html
Oct 08, 2010 | LG LMV1680ST Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Maytag MMC5000 Microwave Oven Logo
138 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
