Question about Fargo HDP5000 Thermal Printer
I have HDP5000 and have a problem that after printing the card doesn't eject and have to pull out manually
    Guru:
  • 528 Answers
Hi. Since the HDP5000 is a modular printer, the main cause of this is a loose connection between the flip station and either the printer or the laminator. Try pushing the printer together tighter; if this fixes the issue, be sure you turn the printer upside down and secure the modules together with the correct screws. There are 2 screws per connection.
Posted on Jul 08, 2010
ERROR MESSAGE 246
There was a communication
failure between the Printer
and Laminator.
FARGO Electronics HDP5000 User Manual Page 96
Feb 25, 2016 | Fargo HDP5000 ID Card Printer Dual-Sided -...
Hdp5000
are you using the printer as an USB or network printer?
Normally its changes when you restart the printer its install it it again and also its bring an other seating again.when ever you start it you need to go preference and check what ever setting you used .please let me know.
Jun 13, 2014 | Fargo HDP5000 Thermal Printer
Card would not eject properly
error 68 mean the card is jam in the print station or in the flipper area.
you either clean the card part and flipper very well.or you may need to change it.
thanks
Mar 14, 2014 | Fargo HDP5000 Thermal Printer
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Ribbon miscue on cyan fargo hdp5000
There are a few things which could lead to a ribbon miscue. The most obvious would be your firmware. Go to Fargo's site and download the latest firmware patch. Your printer may driver be corrupted, so uninstall and then re-install it. One other possibility is that your printer has a faulty ribbon sensor which would need replacing. I hope this helps
Aug 11, 2012 | Fargo "HDP5000 Single Sided Card Printer,...
I have ribbon and am using photoshop,how do i print uv with hdp5000?
To print with UV on a Fargo HDP5000 printer you first need to get a UV color ribbon: YMCFK. The part number is 84061.
After you have your UV ribbon installed you will have to load your cards and tell the printer where you want that special UV logo/design to go. The easiest way to do this is by using Asure ID Solo 7 software. This design software is made by Fargo and has a check mark box on the top where you can either turn the UV design on or turn it off depending on how you plan to create your card. Asure ID Solo 7 costs about $150 but it's very easy to use and makes the print process easier.
There is a second option which involves not using Asure ID and instead creating your UV design through Fargo's "Work Becnch". This process of creating UV designs through work bench is slow and not the most efficient but it is free.
Sep 28, 2011 | Fargo HDP5000 Thermal Printer
Cd in macbook wont ejec
This can be a problem. First try rebooting the machine, and holding the eject button when you hear the startup tone. Hopefully, that will force-eject it.
If that doesn't work, you'll need to get creative. Get a playing card or something similar, and put some rolled-over tape on one side close to the edge, so there's a sticky side out. Turn the computer off, and try to get the playing card into the CD drive, with the tape making contact with the stuck CD. Reboot, holding the eject button when you hear the eject button again, and pulling the card out. Hopefully, the CD will come out with the card. If it doesn't work, just keep trying, and you'll get it out eventually.
Generally what causes this is keeping CDs in the computer for an extended period of time, especially while the computer is powered off. Make sure you remove all CDs before moving or turning off your computer.
Sep 07, 2011 | Apple MacBook Laptop Computer Mac...
Fargo HDP5000 HDP5k H5k Ribbon Breaks Error 97
You need to update the printers firmware. 9 times out of 10, this is the issues I see.
Go to HIDglobal.com. Under the support tab, select Drivers & Downloads. From here, populate the drop down menus with Make and Model. Compare the available firmware with the firmware version current installed on the printer.
Hit [Options] then [Next] on the printer to figure out the version.
On this same web page, make sure to download the Fargo Workbench Utility. It gives you the ability to update.
Aug 06, 2009 | Fargo HDP5000 Thermal Printer
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
Can't eject broken XD card.
The reason why it cannot be ejected by software b'coz the pin that is used to eject it was broken.but you can manually eject it by using a twiser or if not you may open the device carefully and pull out the broken card.
Sep 22, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fargo HDP5000 Thermal Printer Logo
131 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
