Question about Dishwashers
The water does not drain otherwise all the cicles work what should i do?
  • 3 Answers
Check for a clog first, but if it's not that it may be the piston and nut assembly. Open dishwasher, unscrew mesh panel along back wall. Piston assembly is plastic and sits in there. It may be bad. Needs to close completely for water to drain out.
Posted on Jul 08, 2010
Maytag mah8700aww clothes wet after cicle
You might need to replace the drain pump. Make sure to listen if you hear the pump kicking in
Jul 25, 2012 | Maytag Washing Machines
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
My dishwasher want run any cicles
check the out flow tube and see if its blocked..... if its not see if the food grinder in the bottom is blocked
May 28, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Re: machine can't drain the water.
Need a more info but lets see if the machine wash ok but dont go to the nex cicle you got a timer problem, the contacts of the timer could be dirt or worn out some times "ants" blocks the contact and just spray them with a contact clenear spray is the solution but be carefull disconect the machine from the ac outlet before work in that area if not then change the timer....good luck and rate me
Feb 17, 2008 | Avanti W789SA Top Load Washer
Flashing lights
You have a heat problem, using a test meter check the heater element, then check the thermostat if niether of these you have a PCB fault Regards Engineer
Mar 15, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
