Question about Seagate Computers & Internet
1TB Seagate Expansion External Drive is connected to my XP System Computer but is not recognized except for green light showing in the new unit. Should I return it to the vendor ??
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Jul 08, 2010
  • dufton423 Jul 08, 2010
    I will attempt to carry out task as per your instructions.
    Hear's hoping.
    Richard.
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.em?
Sounds like driver problem to me. Re install the driver by using installation disc, or if you have lost your CD, than use this Driver Update Software to update. I hope this helped.
Brian
Oct 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Install seagate expansion
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, and assigning logical drives. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar. You may want break down the 1TB down to a few partition because of the large size.
Aug 30, 2012 | Seagate 1TB Expansion External Desktop USB...
I purchased a seagate expansion 1tb in 3.5". initially when i plugged it into an usb port,(LED lit) it doesn't recognized by my Vista home premium 64-bit. i plugged it and waited for several...
> I purchased
Brand-new, I presume?
> is it a failed HDD
Yes. Take it back to where you purchased it, and get them to replace it, under warranty.
> software problem
No. It shows-up in "disk-management" as a recognized, but not-yet-initialized, device.
Thus, all the software to support it has been correctly loaded.
Exercise the warranty.
Feb 17, 2011 | Seagate Expansion 1 TB USB 2.0 Portable...
My seagate 1tb external harddrive is not recognised by my laptop. system is windows vista
Is it recognized when connecting to another computer?
If not, then either:
* the USB-to-disk-drive adapter inside the casing has failed,
* the disk-drive inside the casing has failed.
If the former, then disassemble the case, and remove the disk-drive,
and connect the disk-drive as a "slave" drive in a desktop computer,
to see if the files on the disk-drive are still accessible.
If the unit is still under warranty, exercise the warranty, to get a replacement.
Jan 05, 2010 | Seagate Electronics - Others
PS3 wont recognize my Seagate?
press triangle and select show all i think should do it
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Computers & Internet Logo
53 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
