? 4:21
www.youtube.com/watch?v=iB7p0PKrDIA
Jan 1, 2012 - Uploaded by Ryan Kucan
1992 Acura Legend Manual Transmission problems ... How toremove the shift linkage pin from a Honda Acura transmission - Duration: 1:56.
Fuse 16 (15 Amp) in the Power Distribution center (PDC) powers circuit M1, (20 gauge, pink) which goes from the PDC to splice S135.
. From S135 it goes to pin 25 of the Transmission Control Module, pin 1 of the Underhood Lamp/Mercury Switch and to pin 12 of Connector 1 in the Junction Block.
At the junction block, it feeds Connector 3 pin 3, Connector 4 pin S18, and Connector 7 pin 4.
From Junction Block Connector 7 pin 4 it goes through Connector C314 and powers the Cargo Lamp.
From Junction Block Connector 4 pin S18 it goes through splice S214 and connector C208 to power the left courtesy lamp. From S214 it also goes to Connector C1 pin 9 in the instrument cluster, through connector C207 to the right courtesy lamp, and to connector C2 pin 7 at the radio.
From Junction Block connector C3 pin 3 it goes to splice S361, where it then feeds the right visor/vanity lamp and to splice S347 where it splits off and feeds the overhead module, the left visor/vanity lamp, compass (If equipped) and the dome lamp.
You need a roll-pin punch. That grooved pin is a roll-pin. It's made of spring-steel and they come in standard sizes. Sears sells them in sets with chisels, or individually.
i also happy a motorola c168i and it is asking for network pin and now it says network pin blocked my imei number is #011460008648589 please i get this phone as a gift and i cant use it i need your help my email address is [email protected] thank you i am waiting your reply god bless you.
Complete information : The SIM card protects
your subscription and not the phone from unauthorised users. If you
change SIM cards you can still use your phone with a new SIM card. Most
SIM cards are blocked at the time of purchase. If your SIM card lock is
on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK
is supplied by your service provider. You can edit your PIN and select
a new four to eight digit number
If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
When PIN Blocked appears enter your PUK > OK
Enter a new four to eight PIN > OK
Re-enter the new PIN to confirm > OK
To edit your PIN:
> Settings > the General tab > Security > Locks > SIM Protection > Change PIN
Enter your PIN > OK
Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
> Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
Here is how I solved this problem. If you pull out the paper tray, you will notice two small, white, push pins under and to the right of the pinch rollers. Dip a cotton swab in isopropyl alcohol and use the swab to push each pin in and out a few times, thus cleaning the pins and the holes that guide them. Give it all a minute to dry and reinstall the paper tray.
