Question about Video Game Consoles & Games
One of my rings is flashes red, it is the second quarter going counter-clock wise. Please tell em what this means and how may I fix it. Thank you.
    Sergeant:
    Champion:
  • 427 Answers
When this happens, this shows thet there is an error. It sould show you an error code. The only ways to fix it are call microsoft, or if you know hgow to, fix it yourself.
Posted on Apr 18, 2008
Altura 68'' ceiling fan only operates counter clock wise. Removed remote control function. Operates by 3 speed wall switch. How do I operate the fan in the clock wise position. Installed in 2010. It just...
If there's no reverse switch on the fan you won't be able to unless you put the remote back. Also, It should be going counter clockwise.
Aug 09, 2014 | Dryers
Rings of death
check out this site it will give you what your codes mean.
http://xbox-experts.com/
May 28, 2010 | Microsoft Xbox 360 Console
On adjusting headlight on 08 tundra does clockwise
clock wise should pull light up. counter clock wise should tilt down
Mar 07, 2010 | 2008 Toyota Tundra
I got 3 red lights after using it for a couple hours then 2.
My xbox is not working the lights on the start button is flikering & the lights around the center are flashing in a counter clock wise ring?????????????
Mar 02, 2010 | Microsoft Xbox 360 Console
Since the distrib. goes counter clock wise, so for 1995 ford mus
What engine is this. Ford inline 6 cylinder or V8
Oct 11, 2009 | 1995 Ford Mustang
Change headlights on forenza
First find the access cover if it has one it will be a rubber plug about three inches diameter pop it out find the harness and disconnect. loosen the plastic lock ring thats around the perimeter of the connector, turn a quarter turn counter clock wise and remove. the bulb should pull right out. dont handle the new bulb by the glass. Reverse for install. let me know how it goes.
Jan 15, 2009 | 2003 Suzuki Vitara
Ball still not working
I checked the feature of the mouse. The mouse can be reprogrammed only for left and right handed person. I guess you need to get the mouse replaced as we already tried replacing the battery.
Thanks
Nov 01, 2008 | Computers & Internet
Help
Hi There,
Unfortunately it seems as though you have a Hardware fault known as "The Red Rings of Death"
The flashing red lights indicate that you have had an internal hardware failure, probably on the motherboard, which stops the console working altogether.
The only was of solving this problem is by calling the Xbox customer support team. their number can be found on http://www.xbox.com/support
Explain to them that the Xbox has the Red rings on the console and they will probably ask you to send the Xbox to microsoft (Free of charge) for it to be repaired and returned to you.
Hope this helps !
Oct 29, 2008 | Microsoft Xbox 360 Console
Instructns on replacing fuel pump
Not 100% on this one, but here goes. The fuel pump is in the fuel tank.[for sure] On most models they can be removed without removing the tank. Try to get the gas down to at least half full. [lower the better] On the back of the tank you will find a lock-ring. Turn this with a 'gentle' hammer and screwdriver by tapping it counter-clock-wise. Only needs to turn less than a quarter turn. Now the pump can be 'carefully' removed. You have already unplugged the hoses an electrical? Make sure you get it back in place propperly before trying to install the lock ring. And lube the O ring with a few drops of motor oil. If need be just use the engine dip-stick. No Smoking!! Frankster016
Oct 24, 2008 | 1992 Dodge Spirit
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
