Question about Home
I have a Mira Sport shower 12 mounths old. Water has started to leak out of the unit and runs down the outside of the outlet pipe.
  • bloues
    bloues Jul 08, 2010
    Hello Is the leak at the wall where the shower arm comes out or at the head of the shower it self??
    Scholar:
  • 56 Answers
If the water is leaking out the head, unscrew the head and put thread tape on arm of shower were the male thread is and make it tight again, if the arm ... unscrew the arm and put thread tape on the male thread of the arm and screw into feamale thred that is an the wall. if not 1 of those are the problem , clarifi and all give u a solusion
Posted on Jul 08, 2010
I have a Mira sport shower 'it was leaking water so I had to have it removed from bathroom wall,would it be possible led to have it repaired.
Absolutely... Scott Fullerton,
It appears to be a UK item...
My best recommendation would be to contact Kohler-Mira
by using the attached numbers and asking them for a local shower service RECOMMENDATION...
UK
Telephone: 0844 571 5000
www.mirashowers.co.uk E-mail: technical@mirashowers.com
Fax: 01242 282595
By Post: Mira Customer Services Dept, Cromwell Road,
Cheltenham, Gloucestershire, GL52 5EP
Eire
Telephone: 01 459 1344
E-mail: sales@modernplant.ie
Fax: Dublin 01 459 2329
By Post: Modern Plant Ltd (Dublin),
Otter House, Naas Road, Clondalkin, Dublin 22
© Kohler Mira Limited, February 2011
32
(www.mirashowers.co.uk)
OWNERS MANUAL (contact information)
Mira Sport Thermostatic 9 0 Installation User Manual Page 32
Hope this helps
Carnac the Magnificent Carnac the Magnificent
Nov 23, 2017 | Home
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
I have a mira duo shower why does it make a high pitched squeal when in use the shower is onley 3 months old and has done this from new
Hi Derek
I trust you are well
Sounds like it might be a air bubble in the waer pipes, try removing the shower head and run the hot and cold water together for a minute, then remember to FIRST TURN OFF THE HOT WATER then turn off the cold water and replace the shower head and test as normal.
Hope this helps
Kind regards
Aug 15, 2014 | Home
Mira sport electric shower losing heat
It sounds like the heating element is going bad, needs replaced.
Dec 01, 2012 | Plumbing
My mira sport shower when switched on runs afew seconds and stops, then when switched off runs afew seconds then goes off. pls can someone advise. thank you
detach the hose from the shower head and clean the filter screen and do the same with the shower head. When you have the shower head detached turn the water on to the shower and see if anything comes out into a towel or bucket.
Feb 15, 2011 | American Standard 1660.501 Sport Hand...
Mira elite 2 - water leaking from unit
1burst seal due to way too much pressure,2damaged solinoid on outlet going to shower head that has failed to shut down
Jan 17, 2011 | Home
Mira thermostatic shower water dripping from bottom of casing
Switch off the power supply to the shower at the consumer unit, it will probably have its own individual circuit breaker as it is such a heavy user of power. Try now to switch the shower, it should be dead and that is good. Remove the control knobs and remove the front of the shower unit. Check the electrics with an electrical screw driver to make sure that there is nothing that will cause electrocution. Trace the source of the leak, the most likely place is the compression joint to the mains water pipe. Tighten the compression nut until the dripping stops. Dry everything off with a paper towel and check there is no sign of further leaking. Reassemble the front with the knobs and switch the power back on.
May 27, 2010 | Home
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
Home Logo
431 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
