Question about Nokia 6120 classic Cellular Phone
Not charging mic fault
6120c not carging
Posted on Aug 24, 2010
  • 4 Answers
Jaaafaaaest phnn ...
Posted on Jul 08, 2010
Static noise
This is a problem that's not too uncommon. First, you need to determine if the mBox is at fault, as they can be noisy. Test it with another mic.
If the mic is indeed at fault, and is under warranty, I advise sending it to Rode for repair. Otherwise, I can can perform out of warranty service on any Rode mic.
Condenser Microphone Mod Service
May 22, 2012 | Rode NT1A Professional Microphone
Mic problim
If there is no sound heard by the caller then it is possible that the mic of the phone is faulty. You have to check if the mic port is clogged with dirt and so blocks the mic. If so remove panel and clean.
Also you can confirm by using a handfree on the phone. If the head set mic works well there is no fault on the phone motherboard and the solution can be a new mic or a faulty external terminal which can be cleaned.
Dec 20, 2011 | Cell Phones
I have a Nokia 2700 mobile phone and when someone calls me I can hear them but they cannot hear me????
You phone has a fault with the MIC within . Have the small port holes to the mics cleaned out so as to prevent accumulation of dirt in blocking the voice to the MIC.
If this had not helped then you will need expertise to open and check on the board and mic, test individually for working , if not replace the MIC.
Mar 18, 2011 | Nokia Cell Phones
The person i am calling can not hear me
This is usually due to two reasons.
The first reason could be that your mic is set to the mute position so whatever you are saying is not getting into the mic. So therefore, the person at the other end cannot hear what you are saying since the mic is not transmitting whatever you are saying.
Secondly, the mic of your phone could have developed a fault or is broken. As a result, it cannot transmit whatever you are saying too. A very good way to know what is exactly wrong is to try and record a message or any tone on your phone. If you can hear the playback then there is no fault with your mic, but if you cannot hear the playback, then you have to change your mic.
The only way you can replace it is to send it to a repairer and have him fix it for you.
Hope this was helpful? Please comment for more information.
Jan 28, 2011 | Cell Phones
Mic problem i change mic but it not working
The fault can be the mic input amplifier which is not working to increment the signal to the desired level to be fed into the circuit.
So you will need to trace the signal path if you are confirmed with the mic connection and type.
It is fault in the mother board.
Jan 21, 2011 | Nokia 2690 Cell Phone
When I place a call to someone & they answer,I can haer them just fine but when I speak, they cannot hear me.What might the issue be with my headset? Motorola710
The fault is possible in the headset and you will need to check on the mic section. Check on the mic inlet for any block due to dirt accumulating , thereby blocking the passage of sound. Use a good soft fibre for cleaning and clearing the passage. If this wont help you will need to open the head set and ceck on the mic. Use a signal test on the mic to get a response on the answering phone. If so the mic is the main culprit. replace and proceed, However if the fault stays still, it could be the failure of the mic amp, try to solder this area and test. Hope this works for you. Good day
Jul 26, 2010 | Motorola Mobility H710 Bluetooth Headset
How to replace mic on Sony Ericsson W580i
It's actually quite simple to replace the mic. At the bottom of the phone directly to the south of the keypad the cover comes off with a plectrum (guitar pick) and the mic is underneath on a membrane. The mic itself will just pull away from the membrane and then you simply slot the new mic in it's place (be careful not to damage the membrane).
However, in my experience mic problems on the W580i are never actually caused by the mic itself, Mic problems are almost always caused by a damaged internal ribbon cable or membrane, so please don't waste your time with the above unless you are absolutely sure the mic is at fault.
May 25, 2010 | Sony Ericsson w580i Cellular Phone
My nintendo ds lite microphone isn't working!
suspect the mic has gone faulty if it went all of a sudden.
Jul 04, 2009 | Nintendo DS Lite Console
Just had my dv 9000 lap top in for repair... mother board cpu fault... now that i have it back the lights on the bottom left ( for the power hdd and on charge light now not light up... and i'm on skype and...
Sounds like the technician that replaced your motherboard and/or CPU didn't hook up the little ribbon connector that powers those LEDs or Speakers.
the mic itself is in the screen part of the laptop, right? And the speakers are in the "bottom" part of the unit?
wow.
Mar 09, 2009 | HP Pavilion dv9000z Notebook
Telex M-560
may be mic preamp is not working correctely. condenser microphone voltage is very low or mic is fault . check your microphone cable . preamplifer of condenser mic may be leaking .check ur mic driver and audio .
Feb 22, 2008 | Telex M-560 Consumer Microphone
Nokia 6120 classic Cellular Phone Logo
106 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
