Question about Dishwashers
I need a manual for a Heller DWHB4 benchtop dishwasher....can anyone help me out with that? Thanks...Cheryl
4 Suggested Answers
SOURCE: hi there,we are getting error
I have the HDWE12/SS manual, the following may help, or not!
According to my manual error 4 means it is "overfilled", and the possible cause is "too much inlet water". I doubt that is much help but that's all the manual says.
Error 2 is "longer draining time" with a possible cause of "the installation position of the drain pipe is too high"
Posted on Feb 09, 2009
ltldab
  • 152 Answers
SOURCE: Can I get a Goldstar Benchtop dishwasher manual
CONTACT THE MFG CO. OR DEALER WHERE YOU PURCHASED. THEY WORK LIKE OTHER DISHWASHERS OTHER THAN THE WAY YOU CONNECT THE WATER HOOKUP AND DRAIN.
Posted on Feb 26, 2010
SOURCE: I need an instruction manual
www.gafcontrol.com.au/brochures/pdfs/GAF-Whitegoods2.pdf
Hi, please find above your user manual.
Posted on Aug 24, 2010
Just moved into s property that has a heller DWH116 and it runs for 24 hours! Has this happened to you before? I read the manual and looked up online but I dont know what's wrong with it?
http://ernie.awa.com.au/Heller---Dishwasher/default.aspx u can find the manual here for it. in my opinion it sounds like a bad timer which can be changed but if it has quite a bit of age on it, then I would consider replacing the dishwasher itself.
May 21, 2016 | Hardware & Accessories
Heller MIST40B instruction manual
I am assuming this is not a dishwasher but a mist fan.
Try contacting awa in Australia who support Heller brand products.
Ph:
1300 366 144
email:
warrantysupport@awa.com.au
Jan 05, 2013 | Dishwashers
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
Hi - have a DWH16 Heller
disconnect the element and use a test meter across the terminals of the element to check for resistance, no reading or OL will confirm if the element has failed.
Jun 16, 2012 | Dishwashers
Hi, My Bosh lifetstyle dishwasher purchasedin Dec. 2010 is just about 10mm to high to insert under kitchen benchtop. Is there a way to remove the top of the dishwasher because then it would...
If it is a brand new dishwasher you should not be making any alterations to it otherwise it can affect the warranty.
Best to call the company representative and ask.
Dec 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Can I get a Goldstar Benchtop dishwasher manual for model: GDW 051T ?
Feb 26, 2010 | Dishwashers
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
WESTINGHOUSE 906 DISHWASHER
Has anyone managed to find a Manual for the Westinghouse 906?
Dec 09, 2007 | Westinghouse Dishwashers
Dishwashers Logo
202 people viewed this question
Top Dishwashers Experts
