Question about Bodum GRANOS (3020-16US) Espresso Machine
Leaky Bodum Granos with a faulty steam valve switch
Hey I too have a Bodum Granos with a faulty ( leaking) steam valve. I need to know where to source this part. Understand one of your contributors has sourced a metal replacement of the original plastic part. Seems to be a common problem as my service person has 3 other Bodum Granos machines with the same issue. May be a bulk order beckons!
  • 8 Answers
SOURCE: I'm having problems with my
I had a similar problem and had a techo fix it.  He didn't charge - because the solution was real easy. Basically you have a blocked filter. The filter is at the base of the rear column. You need to unscrew the back plate on the column leading up to the head. Once unscrewed you'll find the filter somewhere at the base end. Remove filter wash, reinstall and screw the thing together. Should now run ok. Cheers
Posted on Oct 16, 2008
  • 199 Answers
SOURCE: bodum granos new will not function
the connections to the heating coil element looks faulty.check it.
Posted on Jan 18, 2009
SOURCE: Parts for the Bodum Granos Espresso Machine
If you have a receipt, there is a 2 year warranty on the machine. Bodum will replace it with a new one.
Posted on Mar 24, 2009
SOURCE: All the lamps on the Granos flashes - what does it
Clean it with CLR. I had to turn the steam on and plug and unplug it to get it to work for just a few seconds but that was enough to get some of the CLR into the system. I let it sit overnight and then the next day it would work for 10 - 15 seconds at a time. Finally the more CLR I got into the system the better it worked. I regularly used a coffee maker cleaner but the CLR seemed to break up whatever was in there.
Posted on Mar 29, 2010
SOURCE: my bodum granos expresso machine
Did you find an answer for this? mine is brand new and leaks from the base. I know its been on the shelf at the shop for 3 years, so I'm expecting its a leaky seal somewhere.
Posted on Sep 08, 2011
Im looking for the operating manual for a Bodum Granos coffee machine please
you can obtain your manual by clicking on this site and following the links to download the manual http://www.retrevo.com/support/Bodum-3020-Granos-Coffee-Makers-manual/id/4610dj094/t/2/ or to bring you a step ahead to the following page click this link
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
this site is free to download any manual or instructions and if you have any problems obtaining it through this site message me back along with your email and I will send it to you from my email. Please also remember when our chat has fully concluded to rate how this service has helped in locating your manual for you. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Jan 17, 2012 | Bodum Granos 3020-16 Espresso Machine
My bodum granos expresso machine leaks from the base. would anybody know why. If not is there somewhere I can send it to be fixed in Canada? Thank you:)
Mar 22, 2011 | Bodum Granos 3020-16 Espresso Machine
When operating, water leaks from the edge of the filter holder. Could there be leakages within the water pump system enclosed within the housing? Are there any tools suitable to remove the warming plate?...
Hi had the same problem. Probably it is the steam/hot water valve that leaks. I just bypassed it since you can not find it anymore & is from plastick, not reparable at all. Open top cover, see if at the right, where the handle to choose steam is the plastic valve is leaking or if it is covered with white powder (residu of calc of the vapourated water). If so this is the problem. Disconnect at te bottem of the valve the tube coming from the heater. (untighten the screw, pull tube out the hole, it is a sort of press fitting with a rubber ring) . Do the same with the connection on top of the heating blok and fit the first disconnected tube in it. No leak anymore. You can not have heated water or steam anymore. But coffee works again. Best is also to fix the staem handle into the neutral position, or disconnect the wires on the switches an put them permanently in the neutral status. (one switch is closed, the other is open. So nobody can trigger the steam anymore. Will not be ok since tubing is changed. Succes.
Feb 27, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
Jan 07, 2010 | Bodum GRANOS (3020-16US) Espresso Machine
Pump activates put coffee does not drip instead it water comes out the top of the pod handle
I had the exact same problem about a year ago. I bought a replacement valve from Bodum here in Denmark, where I live.
The cracked valve was made out of some sort of plastic, but the new one I got was cast in metal.
The machine has been working perfectly since.
Oct 07, 2009 | Bodum Granos 3020-16 Espresso Machine
Feb 21, 2009 | Bodum Granos 3020-16 Espresso Machine
Bodum granos new will not function
Jan 18, 2009 | Bodum Granos 3020-16 Espresso Machine
I'm having problems with my Bodum granos it is not dispensing water for esspresso or manually. It starts to go through the process it then shoots out alot of steam and then stops. The indicator light...
Apr 03, 2008 | Bodum Granos 3020-16 Espresso Machine
Bodum Granos 3020 Espressoo Machine
Last year I stripped the machine and found the blockage in a diverter valve. This device switches between the coffee making head or the steamer. I had a blockage in the diverter causing the solenoid to lock in the coffee position that was also blocked. I flushed the system out with Oust cleaner.(very quick and effective) I then reassembled the machine and put sachet of oust with four times as much of filtered water. Then I switched the machine on and passed half the through the coffe head and steamer at full heat. Left for 10mins. then passing the rest through, cleaned with filtered water and away it went. Fixed!!! email gethudall@hotmail.com
Feb 18, 2008 | Bodum Granos 3020-16 Espresso Machine
This is not a fix but it may be a way to at least get an espresso without milk. I opened the panel on the back and removed the to wires at the top of the circut panel. They are both fixed to a plug so all you have to do is gently pull. This turned of the steam/water function and the the water came through the head as it is suppose to. I did not get all the parts with mine so if anyone tries this please post the outcome. Remember to unplug the machine before you open the back. I will post the real fix if I figure it out.
Oct 26, 2007 | Bodum Granos 3020-16 Espresso Machine
Bodum GRANOS (3020-16US) Espresso Machine Logo
91 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Peter Meixler
Peter Meixler
Level 1 Expert
CrisO
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
