I have a vulcan silhouette manual wall furnace that gets really hot and the grill and vents are starting to warp the thermostat doesnt seem to be working, should i still be using the heater...
  • 29 Answers
YOU MUST HAVE THIS THING CHECKED OUT BY AN EXPERT. IT IS A FIRE HAZARD. Even if the thermostat was a closed circuit, the furnace would be working all of the time but it would not be overheating to the point of warping parts. You are either overfiring or your blower is not running all of the time. If it's a blower problem, clean out the dirt and dust and oil the motor. If the motor is not running, replace the fan control or the motor. If the furnace is overheating, your gas regulator might be bad allowing to much gas pressure to the furnace. Also, make sure that the burner orifice's are the correct size for the heater.
Posted on Jul 08, 2010
Why is it still running hot?
no doubt you have a blown head gasket .all the venting in the world will not help it .
Oct 17, 2015 | 2001 Oldsmobile Silhouette
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
The top grill on my Vulcan wall heater gets very hot is this normal please let me know thank you
this is normal as the wall unit heats and hot air is blowen into the room the grills will get hot
Jun 11, 2011 | Heating & Cooling
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ...
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Apr 11, 2011 | Empire Direct Vent Wall Furnace;...
Sticky manual gas valve
Sounfds like the thermostat is on the blink.?
Oct 17, 2009 | Heating & Cooling
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Hi there, I have a Vulcan Gas Wall Furnace Heater 26.4. Would you please tell me where I can get manual book or how to use it. Thanks! Paul
Hi
Please see this link to view/download the manual fro your heater---
Vulcan Gas Wall Furnance Heater
Please accept this solution and ask for any assistance.
Thanks
Rylee
Mar 29, 2009 | Vulcan Heating & Cooling
Heating & Cooling Logo
528 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
