Epson printer rx420 has fix "paper jam" lightwithout paper jam.when I handle the rollers located inside the paper feeding slotthe printer works good for one time
  • 6,826 Answers
Something is worn out on it. recommend a new printer rollers and sensor, or if this is unavailable, a new printer. They're not expensive.
Posted on Jul 08, 2010
Epson wf-2530 printer error see your documentation
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Dec 16, 2013 | Epson WorkForce Office Equipment &...
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper won't feed into printer. Always gets jammed
    you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
    Jul 19, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    Epson cx3800 paper feed problem
    no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
    Jan 29, 2009 | Epson Stylus CX3800 Printer
    Paper jam epson stylus 5400
    1. Turn the printer off and open the access cover.
    2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    3. Turn the printer on, load some paper, and press the Form Feed button.
    4. Watch the paper as it feeds through and try to determine where the jam is occurring.
    5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    7. Turn the printer off.
    8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    Dec 08, 2008 | Epson Stylus CX5400 All-In-One InkJet...
    Always Paper Jam in Epson Stylus CX3500
    Nov 26, 2008 | Office Equipment & Supplies
    Epson R220 paper feed.
    TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
    Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
    Please give me the name of a printer that WORKS with writing checks in Quicken using Windows Vista 64. My HP all in one does not - printer jams every time.
    HP will work. The jam is a paper problem not a hardware or software issue. Try line feeds without printing. HP also makes the best printer paper so don't skimp on that. Moisture in the paper is the most common paper jam problem aside from debris getting into the rollers. If line feed fails then physically inspect the whole paper path. I have Canon, Epson, Dell, HP and Lexmark printers with Quickbooks Pro. They all work. Paper is your problem barring a banana falling into the rollers. Never leave paper in a printer for a long time as it will stick to itself. Steve
    Oct 21, 2008 | Computers & Internet
    How to fix paper jam Epson CX3650?
    Please perform the below steps.
    1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    6.
    Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
    7.
    Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    CREDITS: nanicool
    IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
    I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
    THANK YOU
    REGARDS
    SWEET RASCAL
    Jun 28, 2008 | Epson AcuLaser C3000 Printer
    Won't feed paper
    Hiya .. Your roller guides.. just need a general clean... and the sensors located just on the inside of the printer at the bottom where the paper sits ..
    Regards Faggly
    Mar 25, 2008 | Epson Stylus Photo R300 InkJet Printer
    204 people viewed this question
    k24674
