Question about Poulan Garden
How to change fuel lines on mcculloch 31cc MT765
I took over a job on replacing a priming bulb. I'm not real sure on how the fuel lines get hooked back up, I've tried different combinations. What am I doing wrong?
jgwhomeequip
  • 1902 Answers
SOURCE: 323L Husqvarna trimmer
This sounds like the carb needs to be adjusted like it is letting to much fuel into the cylinder. There is supposed to be fuel and air mixture in the cylinder to make it fire. If there is to much fuel what will happen is that it will just build up in there and the air wont get hot enough as it compresses to start the engine.
Posted on May 21, 2009
rycgl
  • 1545 Answers
SOURCE: trying to replace the fuel line and the primer
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Posted on Aug 07, 2010
  • 2239 Answers
SOURCE: PowerMac by McCulloch PM425AV-18 38cc.
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Posted on May 15, 2011
  • 6 Answers
SOURCE: Ryobi 31cc 17" trimmer. When I pump the prime bulb
need to relace the prime line with a longer line...
Posted on Jun 28, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I own a mcculloch mt270x and it will not start.
Hi stevej31...
Screw you idle screw in to about 1/2 to 3/4 turn open from seating to the bottom of the threads...spray a little starting fluid into the carburetor and try to crank it again.
Did you use compressed air to blow out all passages in the carburetor? If not then do it, because dirt and debris will plug your air/fuel passages and cause the weedeater not to crank.
If you have to rebuild your carburetor then I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Sometimes the diaphgram may look good, but be a little too stiff to act properly as the fuel pump.
If the machine is over a couple of years old then...I highly recommend that you rebuild your carburetor completly
Please take time to rate me
Posted on Jun 29, 2011
Testimonial: "The info was helpful.Will try the solution suggested"
My McCulloch 250cxl strimmer wont prime, new bulb, cleaned carb, new fuel lines
switch fuel lines,the one with filter is carb,the one without is the primer
Jun 26, 2015 | McCulloch Garden
Install fuel lines McCulloch 1838av chainsaw
to replace the fuel line you need to remove the cover over the carb and the fuel cap. (empty all fuel from tank) then use a small gauge wire to fish out the end with the filter in the tank. attach a small piece of small gauge wire to the fuel line. then remove the old line from the carb and pull the old line back from the tank. to anstall the new just reverse the operation.
Nov 06, 2014 | McCulloch Garden
Primer bulb
Hi Bob McDonnell....
Here is how your fuel should be routed...
Please rate me
Bud
Sep 26, 2012 | Garden
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Mar 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
363 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
