Question about Swiftech MCB-120¿ "Radbox" Radiator/Fan Housing
How do i connect radiator fan to ignition on a ford capri 1990 model
    Problem Solver:
  • 8 Answers
Maybe you are interested in this :
source:http://www.laptopcpufan.com/dell-laptop-cpu-fans-c-1.html
Posted on Jul 13, 2010
SET TIMING ON 1990 FORD TURBO CAPRI
bridge 2 connections on diagnostics connector for EFI models,remove and block vac lines on carby models
Feb 12, 2015 | Ford Cars & Trucks
Fuse box for 1990 ford caprie
This is already on the site. Check the following answers to this issue.
Fuse diagram for 1990 Ford Capri convertible
Feb 09, 2015 | Ford Cars & Trucks
Wheres the fuse box on a 1990 ford caprie
Check this thread for answers similar to what you need.
1990 Ford capri fuel pump fuse
Fan relay can't find relay on 90 ford tempo. Changed thermostat already. Radiator fan just quit working. Can't find location of fuse box for fan either. Can you post a picture of location? Thanks
i always hook the fan to ignition so when key is on so is fan keeps motor running cooler . the temp switch is easy to locate just follow wires but I always just run it to ignition
Aug 07, 2014 | 1990 Ford Tempo
Radiator fan does not work
That's bad and it could be that your Electronic Radiator Thermostat is causing all the problem as it tells the fan to come on or stay off.
May 01, 2014 | 1990 Ford Tempo
My capri 90 wants to start but just wont,i have changed spark plugs,leads,dizzy & rotor,car has been serviced new trans & today i am waiting for nwe ignition coil,i just dont know what problem is...
check firing order, i think its 1342. but double check on line. i could be wrong. if you are still having problems check for fuel. it could be a clogged fuel filter or a bad fuel pump.
Apr 18, 2011 | Ford Escort Cars & Trucks
FORD CAPRI 1990
My wife had a mid 80's capri and the latch/release button was on the drivers side door pillar at the back of the door near the bottom of the pillar, the door had to be open to see it, there was a second one that we only found when selling the car on the bottom of the drivers side door arm rest. Not sure if that helps as yours is newer but it might give you a couple of more places to start. On my son's Mercury Topaz you have to open the glovebox and push a semi=concealed button on the right..Those lovely engineers at Ford! lol...
May 11, 2009 | 1994 Ford Aspire
Cooling fan only seems to work when wired straight to battery
try connecting the wires on the sensor together to see if it is faulty. if the fan kicks in then it is.
It is normally on the radiator or the thermostat housing.
If you are unsure what it looks like, it's a bolt head with 2 wires attatched, bridge the wires with a screw driver with the ignition on, if the fan kicks in then the sesnsor is faulty.
May 01, 2009 | 1991 Mercury Capri
Radio Code for 1990 Ford Capri
dealer or manufacture but sometimes the code if stock will be on a sticker on side or bottom of radio starts with security sometimes this code will also be inscribed in the glove box codes
May 20, 2008 | 1990 Ford Escort
Computers & Internet Logo
103 people viewed this question
Top Swiftech Computers & Internet Experts
David Payne
David Payne
Are you a Swiftech Computer and Internet Expert? Answer questions, earn points and help others
