Question about Samsung WF337AA Front Load Washer
My machine starts to fill but then stops whilst flashing de I know it means door not it means the door is not shut (from reading the manual) but my door is closed help ?
  • Samsung Master
  • 17,129 Answers
Possible fault could be with the door closing swtich, the inlet filter, the inlet valve, low flow of water or fault in the main board. you will have to check this out one by one, open the door and inside the latch lock, there is a limit switch. use a cleaning spray. next check the inlet pipe connection, open to check for low pressure , dirt in the filter. Next you need to open the panels and see if there is any wire damage, insect attack on PCb. The water level sensor also could be another culprit. Since the PCB is epoxy layered it wil be difficult to check the componets. But try this out see if this advice helps..Good Day
Posted on Jul 08, 2010
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
My LG Turbo Drum 6.5 keeps flashing dE after filling and beginning the wash cycle. Help!
problem with the door swich,,or door swich harnes might demage some where or bitten by the rat.kindly check properly. replaced the door swich.
Feb 22, 2014 | LG Washing Machines
LG wf-t6517tc, stop after fill water, dE code error
Strange that it should fill as that means door error. You would think it would not fill if it thinks there is a door error. Have you tried switching off, unplug leaving for a few mins? If you can empty it check the door seal,/ latch it may require a new door switch.
Also check that the pump filter is not partially obstructed, be careful water will come out when you check. I read that in another post, I also read that it means drain error but that is at odds with what is written here: read this below it should help and there are pictures
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
regards
Jan 27, 2011 | Washing Machines
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
When you start a cycle the washer fills then turns then sounds as though its trying to empty the door lock light flashes and 2 other display lights flash
It means your door is not shutting or latching
Check for debris and nothing stopping it from shutting
If not replace door latch(some parts lists call it door switch)
its most likely not actuating so it wont advance to the next part of cycle.
if not latch could be bad control board, id try latch first is cheaper and more common
May 02, 2008 | Washing Machines
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Samsung WF337AA Front Load Washer Logo
215 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
