Question about LaCie Big Disk Extreme 500 GB Hard Drive
LaCie Big Disk 500GB not showing up
I have a macbook and a LaCie Big Disk Extreme 500 GB Hard Drive 300749. The two used to work fine together, but one time the LaCie just stopped being recognised on my desktop. Its light still turns on and it makes noises when a cable is being connected, but it doesn't show up on the computer. Please help - I have a lot saved on that LaCie and I don't want to lose it!
    President:
  • 1,768 Answers
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Posted on Jul 08, 2010
I bought today a lacie hard disk 500GB and instead of 500GB has only 9.99 MB space.What's the problem?
Sounds like your have a 9.99mb partition on your drive with the rest being free space.
If you are running windows goto the Computer Management program and check under storage> disk management to see if your 500gb drive is there. if it is delete the existing partitions and reformat the entire disk to NTFS
May 21, 2011 | LaCie Big Disk 500 GB Hard Drive
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie Big Disk Extreme 500 GB Hard Drive Logo
382 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
