Question about Dymo LetraTag QX50 Thermal Label Printer
Prints faintly some letters as if it was running low on ink. i don't even know if it takes ink at all
Check whether letters with faint print are coloured
Posted on Jul 08, 2010
I have an almost full black ink and my color ink is running a little low.. but when I did a test page.. color prints, but the black does not.. I did a couple cleanings.. like 4 times.. and totally wasted...
because you don't use it enough the nozzel is probably blocked with dried ink, even the cleaning option wont work in this case, the only thing you can do is to get help from a professionnal technician to unblock the nozel, some times diping the printing head in hot water unglogges it and some times the technician needs to force a cleaning/ink solution through the nozel with a surringe, but what ever you do (DO NOT USE ALCOHOL) you will damage the print head.
Aug 18, 2011 | Epson WorkForce 600 All-In-One InkJet...
My printer s only printing the main headers and footers of documents and nothing in between, also when i print from a pdf file the print is very faint with letters missing, help please
go into setup and try printing a test page, if this prints, the printer is ok and the source of your print is at fault. as for the missing letters and etc, it sounds like you are out of ink or the print head is dirty, try cleaning the head (the software that came with your printer allows you to clean the heads, but be aware this takes lots of ink to accomplish.
Mar 08, 2011 | Epson Stylus DX8400 All-In-One InkJet...
Have installed new ink cartridge. still getting low inw warning
The low ink cartridge warning is nothing to worry about. If it prints, it prints. Most modern printer cartridges have a chip on it which lets the printer know when the ink is low. When you run low on ink, it sends a message to the printer which sends a message to the computer telling you to refill the ink. The problem is that it doesn't go away once you refill the ink. It still prints, you just get a notification whenever you want to print. You can still use it up until that new cartridge runs out of ink. :)
Feb 21, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I am printing 3 pages the print on the pages are faint in two of the 3 pages. It is not low on ink because it prints the last page just fine. It's faint like its out of ink but it is not out of ink . ...
Squeeze a running garden-hose, and the water will spout out, but at a diminished rate.
If your printer has "nearly" clogged ink-paths, then the first page or two will be diminished, until the ink "washes" the walls of the ink-path, to finally allow more ink to flow through than on the first page(s).
Use the HP "Printing Assistant" software to run a "print-head-cleaning" cycle, to try to "unclog" your printer.
Dec 01, 2010 | HP Deskjet F340 All-In-One Printer
Trying to replace the black inck cartridge and cannot get the cartridge holder to stop at a position for me to pull out the old cartridge and insert the new cartridg. I've have an Epson Stylus NX1000...
Found this on the Web for Your Printer. You can download the Manual from Epson.
If you find this helpful, pls rate me.
http://files.support.epson.com/pdf/nx100_/nx100_qr.pdf
Checking the Print Head Nozzles
If your printouts are faint or have gaps in them, some of the nozzles in the print
head may be clogged or ink may be running low in one or more of the ink
cartridges. Follow the steps below to check the print head nozzles.
1. Load letter-size paper in the sheet feeder.
2. Turn off the NX100 Series.
3. Hold down the y Stop button as you press the P On button to turn the
NX100 Series back on. Hold down both buttons until the P On light begins
to flash, then release the buttons.
Cleaning the Print Head 21
4. Check the nozzle check pattern that prints to see if there are gaps in the lines.
5. If there are no gaps, the print head is clean. If there are gaps or the pattern is
faint, clean the print head as described in the next section.
If print quality has declined and the nozzle check pattern indicates clogged
nozzles, you can clean the print head. Print head cleaning uses ink, so clean it only
if necessary.
Note:
You cannot clean the print head if an ink cartridge is expended, and you may not be able
to clean it when a cartridge is low. You must replace the cartridge first (see page 23).
1. Make sure the NX100 Series is on and the B ink light is off.
2. Hold down the y Stop button for three seconds to start the cleaning cycle,
which lasts around one minute.
Caution:
Never turn off the NX100 Series during head cleaning or you may damage it.
3. When the P On light stops flashing, run a nozzle check (as described on
page 20) to verify that the print head is clean.
4. If there are still gaps or lines, or the test patterns are faint, run another
cleaning cycle and check the nozzles again.
Note:
If you don’t see any improvement after cleaning the print head two times, turn off your
NX100 Series and wait at least six hours to let any dried ink soften. Then try cleaning
the print head again. If quality does not improve, one of the ink cartridges may need to
be replaced. If that doesn’t help, contact Epson as described on page 31.
If you do not use your NX100 Series often, it is a good idea to print a few pages at least
once a month to maintain good print quality.
Good Luck and Please rate me.
Jan 13, 2010 | Epson Office Equipment & Supplies
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Prints faint and cuts of the top and bottom of some lines
The ink in the cartridges has dried up. Replace them.
Feb 01, 2009 | HP DeskJet 950c InkJet Printer
Won't print black ink.
Called kodak support and they sent me new printer heads.
Jan 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Won't print except really faint color
Finally - continued to do further print head cleaning (about 6 times, included 2nd level) and finally started printing black again.
Aug 23, 2008 | HP Photosmart 8250 InkJet Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
290 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
