Question about NewAir AC-12000E Portable Air Conditioner
How wide is the exhaust tube?
I have to vent out of a basement that has security bars on the windows. I think they are fairly close together. Can I squeeze the exhaust through them--and then put it through the window?
  • 29 Answers
You cannot restrict the exhaust duct size or you will restrict the air flow and thus reduce or stop the cooling. It might even ruin the unit.
Posted on Jul 08, 2010
I have a GE XL44 that I inherited in my new house. For some reason that I cannot figure out, the previous homeowner cut a circular hole in the floor below the stove and ran a vent line (looks like a six...
It is possible that a down draft venting stove such as a Jenn-Air could have been previously installed and now there is this stove that doesn't need this vent system.
Dec 02, 2012 | GE Kitchen Ranges
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
Is there a way to vent a basement bathroom without cutting into the cement foundation
What is in the room above the basement bathroom?
And how large is the diameter of the vent pipe you need to run?
Do you have a maximum number of elbows, and runs of feet maximum you can't exceed?
Is the Frame wall above the foundation, accessible by going up thru the ceiling of the bathroom, and the elbowing over and into the outrside frame wall at that point?-- and then up a ways, and then out thru the outside wall?
Another possibility would be: How far to a window, or vent already in the basement?-- Could you run the piping there, and then out?
How thick is the concrete wall?-- Is it reinforced Concrete-- or just Masonry Block wall? A block wall is not as hard to get thru--
I know I asked a lot of questions-- but maybe it helps you think thru your options?
Le4t me know if I can help further.
Mack B
Jan 29, 2011 | Fantech Fans Exhaust Fan In-Line
I have a 3 year old ge smartwater gas water heater. in our ontario winters, the gravity vented unit spills exhaust into the basement because the pipe and chimney get too cold after the heater is off for...
Id try raising the chimney until you can get the smoke from a piece of paper to get sucked up under the draft hood. I believe theres a different problem then a cold pipe.raising the chim.might not be the answer.
Jan 17, 2011 | General Electric GE SmartWater Household...
Dryer drys but gets hot and shuts off when vent tube is attached . When vent tube is not attached it wokrs fine ! Vent tube has been checked is not pluged , it is in the basement .
Our machine has done that as well. Our vent tube worked fine for our "old Standard type" Dryer. The front loaders are supposed to have a short vent tube---I think the manual says like 5-7 feet?
Dec 12, 2010 | Dryers
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
Vent window repair.
To replace the window seal, you first have to remove the vent window assembly from the door. After it is removed, the nut and spring on the bottom of the window has to be removed. Then remove the glass and frame from the vent assembly frame. Then gently remove the rubber off of the frame and install the new one after you replace the top vent bar seals. Reverse the window removal procedures to reinstall the glass and frame. The top vent bar seals requires a special tool to remove and replace the rivets you get with the replacement seal. You need to replace the top vent bar seal before reinstalling the new vent window rubber. When I replaced my top vent seals, it was fairly easy with my removal/installation tool.
Oct 03, 2008 | 1965 Ford Mustang
New bathroom venting in basement bathroom.
Install a window mounted exhaust fan if you can discharge to the outside of the house surrounding atmosphere.But undercut the door of the batroom to allow air coming in into the room.Alternatively firt a door grill 600 x 150 mm size which is more expensive.THe size of the fan should be 50 to 100 l/s of air flow.
Mar 24, 2008 | Fantech Fans Exhaust Fan In-Line
I have a lg dryer model dlg2532w gas dryer it does get warm
if the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
Sep 25, 2007 | LG DLG5988 Gas Dryer
NewAir AC-12000E Portable Air Conditioner Logo
Top NewAir Heating & Cooling Experts
Donni Steen
richie46
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
