Question about Microsoft Windows XP Professional SP2
My computer atomatically on/off
My computer automatically on/off continuously...without booting..processor fan also on/off continuously
    President:
  • 2,340 Answers
1. You have to check your PC power supply unit whether it is functioning properly or your AC power source is ok.
2. Your system maybe badly infected with dangerous objects, like root-kits, malwares, virus, trojans and etc........
Posted on Jul 08, 2010
With using, the computer without reason/ warning got stuck and I forced turn off the computer; then, tried to turn on again. It was not Boot. The power on, but it is stuck in there, no Boot. Help!
A couple of things spring to mind, but difficult not having the machine.
Upgrade to Windows 10 is automatic and your machine is trying to update and finding a problem. I would not load Windows 10 until Service Pack 1 comes out.
Also sounds if the processor is overheating. When you boot up, you can get into the BIOS, often by tapping Delete, or F10. There is usually a prompt onscreen during boot up. One of the screens in the BIOS tells you the processor temperature. If it rises over 60' you have a problem with cooling. The computer has a fail safe feature to save the processor by shutting down.
Sep 02, 2015 | Gateway Desktop / Intel Core i3 Processor...
DELL 8400 MAKES A LOUD FAN NOISE AND WONT BOOT
There are 2 basic fans in Dell tower one for the power supply and the other for the Processor. If your computer is not booting then the Processor fan is most likely to be the culprit. What could be happening is that the Processor fan is no longer turning fast enough to cool the processor, so normal the processor when it over heats there is either protection to switch off the computer automatically or the computer won't boot. The best thing is to change the fan and make sure it is working properly but checking on the cables that they won't entangle on top of the fan to impede it's movement. You can easily damage your processor if the fan is not working properly.
Oct 18, 2011 | Dell Dimension 8400 PC Desktop
Computer Randomly Cuts off
processor overheating. When it gets too hot it automatically shuts your pc down and boots it back up. Even if the fan is running, it could not be supplying enough cool air anymore.
Jul 27, 2009 | Computers & Internet
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Computer crash and restart
Windows restarts without warning
Cause:
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Jan 28, 2009 | Computers & Internet
HP PAVILION LAPTOP SHUTS OFF AND REBOOTS AFTER A FEW MINUTES
Heat related issue.
Computer virus.
Click Ok.
Computer virus
Heat related issue
Nov 12, 2008 | Computers & Internet
Fmv 7000na5
automatically shutting down is an indication of thermal issue or over heating. how ever when you say automatically shutsdown does the computer turns off? try checking your heatsink fan and the heat sink as well as the air vents. make sure all the air vents are free from obstruction and the heatsink is clear of all dust which can prevent the air from cooling your processor. if still it continues change heatsink fan and heatsink. make sure to apply the thermal grease between heatsink and processor
Jun 26, 2008 | Computers & Internet
Fan error - Gateway M305CRV
There should only be one processor fan in this model. The computer may allow you to continue to work, but you should refrain from doing this due to the potential heat damage to your Processor. The reason it "misbehaves" is because as the computer heats up, the processor loses functionality. Usually the end result is that the computer will lock up or crash. Occasionally you melt your processor and it must be replaced.
In terms of replacing a fan, it is more on the intermediate side of laptop repair. If you have never taken a laptop apart before, I would think really hard about doing so, or go to a website like www.eServiceinfo.com that sells repair manuals for your laptop. It will take a good amount of mechanical aptitude to do this and some knowledge of electronics.
Due to the age of the computer, it would not be cost effective to take it to a repair shop since it may cost you almost what it would be to buy a new one of the same model.
Apr 21, 2008 | Gateway M305CRV Notebook
Microsoft Windows XP Professional SP2 Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
