I have a jvc casette deck td -W220 model and my record button won't work and also won't play. Thank from Bryan..
5 Suggested Answers
CLARKPINK55
  • 71 Answers
SOURCE: play button no response fast forward and rewind work
THE capstain belts need changing to operrate the tape lifter mechanism
Posted on Dec 17, 2008
  • 10 Answers
SOURCE: Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Posted on Apr 17, 2009
Grubhead
  • 5151 Answers
SOURCE: I am looking for drive belts for Sony Model
All you need to do is measure the diameter of each belt in MM. Then put "Cassette drive belt ??mm" into Google and you should find a supplier. Belts are not generally specific to any maker. Also you don't need to be precise on the MM. If you are removing them to measure, make a note of how they fit first.
Posted on Oct 07, 2010
  • 11800 Answers
SOURCE: I have a Marantz PMD510 dual cassette deck. Both
There are no fuses in this unit. The decks can't read or record because either the connection switches from the heads to the boards have failed or the power source is no longer active.
You will need to locate the switch by following the data cable coming from the heads and determine why it has failed and how it can be fixed. Then check the connections from the switch to the signal board. Finally check the power : the output of the transformer and the filtering and stabilization stages.
Posted on Aug 16, 2011
JVC TD-W354 Dual Cassette schematic needed...badly!
this is a service manual for you download-able for free.
gylacz
May 12, 2013 | Audio Players & Recorders
JVC TD-W718 double tape deck capstan belt
Probably the wrong belt. It is also possible that your old belt had stretched and the machine was playing slow. Check with a recording of instrumental (not vocal) music.
If you have a little screwdriver you can adjust the motor's speed via the little hole on the back of the motor.
I suggest a plastic screwdriver so you don't short something out.
Using a tuning fork or electronic tuner or musical instrument will help you get the speed right.
Jun 07, 2012 | JVC Audio Players & Recorders
How to hook up to tv
For what purpose? To Record the unidentified TV audio or to Play tapes through the TV's speakers? Any tape deck records FROM a standard Line Level output of another device and plays out TO a standard Line Level input of another device. If your TV has those, go for it.
Looking at manuals may help, too.
Aug 16, 2011 | JVC TD-W254 Single Cassette Deck
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Apr 13, 2009 | JVC Audio Players & Recorders
NOT RECORDING WHEN USING MICROPHONE
Is the mike turned on///broken? test the mic to make sure its not the problem! it could also be mic jack!
Dec 17, 2008 | JVC TD-W354 Single Cassette Deck
Play button no response fast forward and rewind work
Dec 03, 2008 | JVC TD-W118 Single Cassette Deck
103 people viewed this question
 Grubhead
Grubhead
