Question about Boating
Need to know how to drop the lower unit of my johnson outboards 1975 70 hp motor to get to the water pump.. does anyone have any clue or a repair manual
  • 677 Answers
There is the g/box bolts to remove.On the side of the leg will be a plate that gives access to the gearchange rod.It also has to be unbolted.The rod is a 2 piece item with bolts joining the top and lower part.Undo them.The gearbox should now drop off.If it doesn't the driveshaft may be seized in the bottom of the crankshaft.If this is the case,it could turn into a major fix.Hopefully it isn't.Hope this helps.
Posted on Jul 08, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
I have a short shaft Johnson 6hp outboard, the Jon boat I mounted it on is too deep, and motor doesn't reach water. Is there a way to lower motor? A bracket to lower motor to reach water?
outboard motor manufacturers supply a long shaft leg for just this problem
Talk with your Johnson dealer and check used outboards on e bay
Lowering the whole motor may affect the boat and floatation aspects besides making it harder to steer and start
Apr 15, 2015 | Boating
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I have a 1998 Johnson 130 hp outboard motor. Have already taken lower unit off but can't get it apart. Is there a secret to taking the lower unit apart? I would like to have a diagram.
Here is a site where you can purchase the service manual to repair your outboard motor:
http://www.tradebit.com/G/manuals/-/0-0-johnson+130+hp
Jul 13, 2011 | Computers & Internet
Water pump not working on Johnson 3.3 outboard 2 stroke.
sounds like you need a new water pump impeller.
to access the impeller the bottom of the motor needs to be unbolted and the impeller is fitted to the shaft, it is keyed so it only goes on one way. ( impeller kits will come with new gaskets,grease.O-rings and a new key ). re-bolt the lower unit and test.
c...
Jan 01, 2011 | Sport & Outdoor - Others
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
Need to know how to change lower unit on 1971 johnson 25 hp motor
put into nuetral,undo the five bolts around lower unit,take off sideplate halfway down leg casing,loosen the two bolts clamping the gear rods together,then lower unit should slide down[if driveshaft isnt stuck in the crankshaft spline].assembly is reverse,but take care putting water tube back into rubber grommet,and tighten gear rod clamp only after making sure that g/box is in nuetral,when gear lever also in nuetral,or matched together
Jul 01, 2010 | Light Outboard Motor Boat Bass Fishing...
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
How to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Dec 30, 2009 | Boating
Boating Logo
278 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
