Question about Amana AP077R Portable Air Conditioner
Amana ap077r one button on remote doesnt work, how can i fix, i can press all the buttons on the remote and they work except the down button. do i need a new remote or is there an easy fix to this problem.
  • Amana Master
  • 17,130 Answers
You can fix the problem of the failure of the contact within your remote. First of all you need to understand that there is CARBON contact underneath the pad that you press. Carefully remove the remote control, use a sharp knife to carefully open without damaging. Take the pad and the remote control PCB out of the cover. carefully using a good cloth clean the PCB and the carbon dots under the pad. if you happen to see any maiture/ sweat tugged inside, use a hair dryer to slowly heat up to remove and dry. Now identify the defective pad. You can get to buy the carbon dots but if have any old calculators/ remote that is lying arround, carefull cut off the carbon dot and using a good glue stick it to the problem pad. If your PCB tracks are intact and if the Remotecontroller IC is alright then you have rectifed the fault. Hope my advice helps.Good day
Posted on Jul 08, 2010
Our older model amana wall unit is in the garage and worked fine until we programmed a new remote control garage door opener in there this morning. The ac unit was not on at the time but we went to turn it...
If it says E0 then what this usually means is that the unit was unplugged or power was cut to the unit while the unit was on. It then needs to be programmed again. If its the amana/goodman RSKP0009, you need to hold temp up and down arrows down together for two seconds then press off twice. It will take you into the programming mode. Settings are different for heat pump and electric heat models. If you just need a quick fix to get it to cool, I think you can get away with pushing the heat button a few times and then off. If you did it right the display should go off and the light by the off button will turn on. Press cool and it should work.
Aug 14, 2011 | Amana Heating & Cooling
I'm looking for the product manual for the Amana AP077R Portable Air Conditioner?
how to down low the instruction manuel on this product amana APO77R air conditioner
Jul 17, 2011 | Amana AP077R Portable Air Conditioner
Amana ap077r IS LEAKING WATER FROM THE BACK
Find the evaporator condensate drain and check that it is routing water into the pan
Jun 22, 2011 | Amana AP077R Portable Air Conditioner
Dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Sep 16, 2009 | DISH Network IR Remote Control
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Amana Portable A/C Model#AP077R Remote control worked twice and then stopped working. Replaced batteries twice but no luck. Any suggestions?
I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
Jul 06, 2008 | Heating & Cooling
TV Locked
I hope this helps, these unit were made by akai: here is the akai fix for this problem. Hold down the "F" button on the remote (top left button) and press the mute button. This should make the key go away. Thanks
Dec 24, 2007 | Mitsubishi VS-45609 TV
Problem with remote
This fixes the *Set 1* problem. Set 1 means the remote cannot communicate with the Panasonic DVR. If the batteries go out on the remote replace the batteries stand in front of the Panasonic DVR, press and hold the "1" button and the *enter* button at the same time and hold for 10 seconds.
May 21, 2007 | Panasonic DMR-ES35VS
Amana AP077R Portable Air Conditioner Logo
298 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
