Question about Microwave Ovens
I have a standard ice maker in my GE refrigerator. It is an older model, maybe 10 years. Sometimes it works perfectly, other times after the ice dumps out, the water will continue to flow after the tray is full and begin to overflow in to the ice bucket. It will then some times shut off after a few seconds or a minute or 2, other times I have to unplug the ice maker for it to stop.
  • scott_jahnke Jul 08, 2010
    Pushing up the wire switch to shut off the ice maker does not stop the water from coming in. The unit must be physically unplugged. I'm trying to figure out if the control switch which rides the time cam inside the unit is bad or if the water valve is sticking on.
    Thank you
  • 857 Answers
Sounds like you have some crud in the line somewhere. Shut the water off, remove the filter element, and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter.
It may also be the problem with the valve,Might try replacing the washer or cartridge in the valve,or the solenoid valve it will fix the problem.
Posted on Jul 08, 2010
  • Microwave Ovens Master
  • 6,826 Answers
Ok, this is for a GE refrigerator from 2000 or so. There is a metal wire lever that can be set up or down depending on how much ice is in the ice bucket. You can deactivate it by pushing it up.
Also, there is a website that if you feed your model number in, you can get replacement and do it yourself fix it parts for your ice maker based on your refrigerator model #:
http://www.partselect.com/GE-Ice-Maker-Parts.htm
Hope this helps!
My GE Profile Spacemaker XL(JVM1350BW 002) starts a loud buzzing noise 3-5 seconds after started and is not heating food. Any thoughts or is it dead?
Hello Scott MacAskill,
I would say it is only dead if you want it to be...
BIG noise is USUALLY a bad transformer... Sadly your is about $200 USD... so EASTER egg trouble shooting could be COST PROHIBATIVE.
SERVICE manuals begin at $9.95...
Youtube is generally full of WILDER GUESSES than mine...
Try the on-line support from SEARS...
Just check your prices before buying anything from them...
(my opinion... after getting personal shafted by the 3 TIMES).
Parts are available...
(must be a nice unit.. pretty $$$$ parts)...
I have my own nemesis... a MARVEL 6RFI refrigerator...
My wife loved it for 20 years...
Then it needed serious servicing...
Every MARVEL part I try to buy is marked up $150 just for the name... I find the exact parts & have my Supco Fan for $22 instead of the $172 for a MARVEL fan...
GE is highly serviceable & popular...
If you are willing to put in the time... Newer appliances are just
not quite as good...
They are practically tin-foil (with no added features)...
Your choice... Sadly my wife only tolerates my FIXING ...
She would long ago put it on the trash heap
(ice maker, stainless steel & all)...
Alas (what have you got to lose by trying?)
http://www.appliancepartspros.com/search.aspx?model=jvm1350bw002
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
Apr 25, 2017 | GE Microwave Ovens
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
I have a 21 cubic refrigerator with ice maker. its only 3 years old. just 3 days ago, the refrigerator section stop getting cold. but the freezer still works. i checked out the back of the frig to the...
Inside the freezer, at the back is another fan that circulates cold air from the freeze through out the fridge. Make sure it's running. Sometimes the blade will slip on the shaft and get jammed, or the motor could be defective.
Jun 20, 2010 | Whirlpool Microwave Ovens
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
MW resets power after 2-10 seconds!!!
It could possibly be the touch pad, but since you mention that it runs longer when the exhaust fan is on, I would say your magnetron is heating up.
Say Guest, your "repairman" could have started it cooking, then disconnected the keypad while it was running. Bet he didn't, did he..? *grin*
The magnetron on most GE's have a 5-year warranty now.
Here is a reply I've posted on this problem dozens of times here on FixYa:
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | GE JVM2070 Microwave Oven
GE over the range Microwave shutting off
This is often due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo here:
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You say this is only 2 years old? I thought these models were much older... GE may cover it, but you'll have to contact them.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
