Question about Boating
I have a Mercruiser 228 with an Alpha drive. The engine seems to run a little bit hot. If I leave it sit idling (1000 RPM) for too long eventually the temp gauge will creep up near the 230 degree point. If I increase the throttle just a little bit up (160 RPM) it will be gin to cool down. When running it at higher speeds on open water there is never any kind of a problem. I have been told by several mechanics if the problem was the water pump it would gradually get worse but it does not. It has always done this for the 3 years I have owned the boat. The problem does not get any better or any worse, its always been the same. Is the thermostat or temp gauge defective, or the water pump after all?
  • scott_jahnke Jul 08, 2010
    This opinion agrees with my own thinking, just wanted to bounce it off someone else.
  • 6,826 Answers
Actually, idling this mercruiser 228's engine is like idling a car. The traffic fan in a car will go on because heat builds up with the lower rpm's on the water pump. Also, less wind to cool a radiator.
I see that you noticed a difference between 1000 rpm and 1600 rpm where it cools down and at higher speeds you never have a problem.
If the water pump had a problem like a leak or poor circulation, then this would indicate that you have to replace it.
I don't think anything is defective, based on what you said.
In GM vehicles, for instance, temps rising to 230 or so are not uncommon. If you apply this to your question, I would say that you're on safe ground. Just avoid idling for long periods of time, just like a car.
Happy boating to you.
Posted on Jul 08, 2010
Why is it hard to start my Mercruiser 7.4L MPI after a hot run?
Electric choke? Try retrofitting a manual choke. I think the electric choke is closing over a hot engine, thinking that the engine's cooler than it really is. A manual choke will allow you to start it with no choke at all when you know the motor's already warmed up.
Jul 25, 2014 | Mercury Marine Mercruiser 350 - 454 - 5.7...
Won't idle and surges
May be coil when hot.
Jun 03, 2013 | Motorcycles
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
I have a 2005 harley davidson sportster xl 1200 custom. after bike is at normal operating temp.when i stop for redlight or stop sign, bike idles to fast.i can let out on clutch little bit and it will slow...
If the carb is adjusted correctly, the engine will not idle without the choke when cold. I will usually take at least 3 to 5 miles of riding to get the engine warm enough to idle by itself without the choke. If your bike is a full operating temperature, it should idle at about 1000 RPM. If it's idling higher than this, you need to slow it down a bit.
Remove the air filter cover and look at the top right side of the carb. You'll see a screw there . This is the throttle stop screw. Turn the screw counterclockwise to lower the idle speed to 1000 RPM or so. Blip the throttle and let it settle back to idle. Reset it if necessary. Once set, put the air cleaner cover hand on.
Mar 14, 2011 | 2005 Harley Davidson XL 1200 C Sportster...
1991 F-150, 302 V-8, 5.0L acts like it has a vapor lock. Fuel injected so can't be vapor lock. After driving a while when I push on the gas there is no power. The engine starts to shake and chug like it...
It does seem like you have done a fair bit of work on this beast...just curious to see whether you had performed a cylinder head pressure test....???? If it is happpening more on hot days, it might be wise to check it whilst the engine is hot, i am suspecting a head gasket or head problem ???.....
Aug 26, 2010 | 1991 Ford F150
All the gear lube on my bravo III leaked out. The oil came out where the prop and the lower unit meet.
we had replaced the engine in our 87 4.3 star craft and when we put the omc cobra stern drive back in we now dont have foward gear, we have nuetral and reverse. could it be the linkage or could it be the shifter cable or any other idea's that could be the problem.
Nov 09, 2009 | Garmin Boating
We have a 90 Quattro V8. Last summer I changed
Your V8 Audi has two necessary sensors that malfunction due to their placement in extreme heat on the lower left side of the engine just inside of the header/down pipe connection. They read the flywheel position for the engines computer ECU. The reference sensor is always suspect, but the speed sensor may need to be changed, as well. The wire connectors to the sensors that sit above the FL suspension can be tested, or just replace both sensors to get some quality time with your V8.
Jul 09, 2009 | 1990 Audi V8 Quattro
Weird Toyota Paseo idle problem
So far everything you tell me is normal, the A/C being triggered requires the engine to turn a compressor to get the system working, and on a small 4 cylinder engine, to get enough power to turn it and not stall requires revving the engine a bit more to get more horsepower. But i must admit that the normal idle RPMis a bit low. The best quick fix i got for you is to rotate the TPS sensore a bit. If you wander what TPS means, it means Throttle Position Sensor. You can usually find it easily, since it is attached to the throttle butterfly. So if you're not sure where all that is, start by locating the wire that comes out of the gas pedal, it will lead you straight to the throttle butterfly, and the TPS sensor. Oh, and it usually looks like a small black plastic box by the way. Once you found the little TPS sensor, you need to loosen the screws/bolts holding it in place (usually there are only 2 screws holding it) but don't take them off completely though, just loosen them. Now you should be able to turn the TPS sensor a few degrees either way. Start the car and idle it in park. Now go under the hood and turn the TPS sensor one way to see what it does, one way will get the engine idle lower, and the other way will make it idle higher. Just turn it until you get around 1000 RPM on park and tighten the screws again and you should be fine for a while. Hope this helps.:)
Jul 08, 2009 | 1993 Toyota Paseo
Boating Logo
112 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
