Question about Jura Capresso C1500 Espresso & Coffee Maker
Jura Impressa C5 -stuck/frozen in action
Jura Impressa C5. Indicated it wanted descaling. Did this just as always but it didn't run through as usual -dumped the outgoing water into the tray below rather than through the water/steam nozzle. Now steam nozzle keeps flashing. When I open it to let water out it tries to do so but nothing comes out but keeps flashing like it wants to go further. Tried unplugging, switching off, letting it run with open nozzle for some hours -nothing gives. I need my coffee! Help?
  • 60 Answers
SOURCE: error 6 for jura impressa z 5 ?
Error 6 means that the automatic ceramic valve having a problem reaching the right position. This is usually related to the main electronic board and there is a chance that this needs to be changed. There could be a possibility that the multivalve is broken, but if you can hear it turning when you start up the machine, it`s probably ok. Contact your dealer for service, or call Jura hotline for your local servicecenter; +41 062 389 82 33
Posted on Oct 06, 2009
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
  • 9 Answers
SOURCE: My Jura Impressa xs90 keeps stating fill system,
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Posted on Oct 16, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: Does anyone know how to take apart Jura Impressa
I hope this Jura F90 dismantling guide may offer some clues for your E-series machine. Before you start remind yourself of the risks. In case of a mess up, below I've listed a firm selling spares in Europe. In the UK it is assumed that it you can afford the BMW of coffee machines, you can afford to fix and service it too. However I haven't tried any of the servicing firms so they, and yours could be really, really helpful and cheap. You will need about 4 different torx; hexagonal and possibly unique screwdriver bits to remove all screws. A plastic pry tool (used for mobile phones) will help where plastic lugs hold on the side and top panel. Empty beans; water store and remove the waste tray. On the Jura F90 use pliers to undo two oval headed screws at the back at the top. You'll be able to remove the top panel after using a pry tool to disconnect two lugs at the front edge. You don't want to dismantle the coffee grinder and its hopper. Retain the hopper's rubber seals or glue them in place before you lose them as I did. Four screws hold the central back panel. Slide out a white key underneath the machine (can't recall how crucial this was). The side panels are removed by using a pry tool to release lugs all down the edge where these panels meet the front. Work slowly to manoeuvre the side panels off. If you simply want to clean the brewing unit externally then just remove the panel on the water side. Find the water inlet just where the water tank sits. A screw here allows you to remove a plastic piece - but take a photo of how it slots in. This gives access to the lower end of the brewing unit. If the plastic piece is still it the way, you can ease off the water pipe from the water inlet and put it aside. A number of different brands are made by one firm and branded. Thus the guts of these machines are similar. The brewing unit in the Jura F90 is almost identical in many machines. The screws and attachment places are different. The water inlet and valve are different. Cleaning the parts you can now see may fix a Malfunction 8 without removing and dismantling the brewing unit. The machine is partly operable in this state - cover the exposed electrical connections and remind yourself of the danger here. Thus you can switch off the power when the brewing unit's white wheel is at the top and then at the bottom. In this way you will get access to places causing any jam. You might just need to clear the inner chamber and path for two plungers with two large O-rings. You can see the water inlet nozzle with its o-ring which can perish and cause coffee or water to go to waste. Silicone grease only where the O-rings slide. Leave the other plastic parts ungreased. As I said you might get away with not disassembling the brewing unit. You can however buy a maintenance kit or a new brewing unit from the shop below. You will want to avoid removing the nylon water pipes - unless they're actually leaking. These pipes are held in place with a wire clip (remove with a flat head screwdriver). Ease the nylon pipe with its brass collar out of its socket. The pipe goes into an O-ring in the pipe's socket - this might fall out. Removing a brewing unit is like removing a car engine. The link at the shop below has a pdf (Anleitung_Jura_E.pdf) There is no need to force anything. On the Jura F90 the brewing unit is removed by undoing two obscure screws from the coffee grinder side. I had difficulty removing these and I wish I had taken time to find the right tool instead of wearing down the screwhead. On the electronic side there's an optosensor (encoder) unit held in place with a steel clip. You might remove this to access one of the two screws. At the bottom of the brewing unit, the water inlet valve is fixed to the machine with a single screw. Next, on the water tank side, you'll see two lines of screws that hold the assembly in place. The middle screws of the screws allow you to separate the unit from the gears. The top two holes don't have screws. Coffee machine spare part supplies are not as common in the UK as they are in mainland Europe. You'll find this web useful because of the pictures: www.kaffeemaschinendoctor.de is a German web shop for machine spares AND there's a pictorial of how to dismantle the Jura F90 as a pdf. Google will almost translate it). Juradoctor.de also carry lots of spares but don't seem to ship to my country.
Posted on May 09, 2010
Jura Capresso Impressa 50. It doesn't always rinse when first turned on now and that just started. I unplug and sometimes it resets and is fine and sometimes it doesn't.
Rinsing cycle at start up is electronically programmed function. Unplugging is a temporary solution.
Jura will not sell parts or offer any guidance.
I could look into more details to find an answer but the model Capressa 50 is not listed in my Data base.
Dec 29, 2016 | Jura Capresso Coffee Makers & Espresso...
What is error 5 on my impressa j9
Error 5 is pointing to heating problem. Here are the parts that may be malfunctioning:
1- Thermal sensor not registering heating. Replace it.
2- Heater not heating up. Check continuity on heating element. If there is no continuity, (This is rare). Replace heater (Thermo block).
The problem can be linked to:
1- Missed descaling of machine for extended period.
2- Use of automatic descaling method suggested by Jura. Descale the machine every three months using Manual descaling method.. Services Unlimited Inc Parts Guru Since 1988
Jul 03, 2016 | Jura Capresso Impressa Coffee Makers &...
Can't get system fill message off jura impress z5
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
Oct 05, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
My Jura Impressa C5 does not descale, automatically or manually. If I try the latter by pushing the descale button, all three upper button start flashing, instead of just the middle, with the coffee...
Dont worry about what that bloke said.
I have just had the same problem - the machine thinks it has a filter in it so take it out and follow the manual to deactivate the filter. You will now be able to rin the descale.
Aug 24, 2013 | Jura Impressa C5 Automatic Coffee Center...
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
Jura impressa x90 keeps beeping
call the 'Coffee Boss"  in North carolina.  you will have to find him on Google. his name is heinz and he is the guy that Jura uses when they can't fix it.  He's fixed my x90 3 times.
good luck
Oct 13, 2008 | Jura Capresso Impressa X90 Espresso...
Jura Capresso C1500 Espresso & Coffee Maker Logo
298 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
