Question about Samsung HLP4663W 46" Rear Projection HDTV
RE:COLOR WHEEL I have a bad color wheel for my hlp4663wx/xaa and no one in the Samsung Org. is willing to help. Any Parts House says the BP96-00674A has been discontinued.
  • Samsung Master
  • 1,689 Answers
Did you call the manufacture directly? Did you find out who their authorized service is in your area to see if they would service the set for you?
With many of these manufactures, they may not sell you the parts unless they service the set.
From experience, I found that when most electronics are more than about 4 to 5 years old, there is no longer any manufacture support. The technology and industry is changing too fast, and it is not feasable for them to continue supporting old models.
Jerry G.
Posted on Apr 19, 2008
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Samsung model HLP4663wx/xaa and I just recently changed the color wheel assy. I am on my 3rd bulb, I also changed the ballast recently. Now my problem after the color wheel install is the picture...
if you replaced the ballast your self you may have overlooked a plug to be plugged in, i would take it apart again and check that all plugs are as they should be, for the problem started right after you replaced the lamp power supply. if a repair shop serviced the unit you may be part of a scam and if so get a 2nd opinion from a different repair shop
Jan 10, 2012 | Samsung Televison & Video
I have a Samsug TV Model #HLP4663wx/xaa and when we turn it on we get a hum. The lamp light was on, so we replaced that but the hum is still there. Any suggestions?
I would be the farm that its a bad color wheel. Depending on your mechanical ability you might can swap it yourself. No soldering is required but quite a bit of dis assembly will be required.. Part number for the model you listed is BP96-00674A Heres a link to MCM that show it in stock
Oct 18, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Oct 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Replace Color Wheel
go to you tube there is a video there that shows you how to replace it you will find it just to the left of the lamp when you pull it out
Apr 12, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel problem on my HLP4663WX/XAA
The color wheel is not working, and failed in green. The best case is a cable is loose, color wheels typically have a two pin power connector and a ribbon cable for phase locking. If it is not these connections, you will not be able to fix it yourself.
Sep 21, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
 This is the correct color wheel.
Oct 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
