Question about Dryers
F2 error code
I keep getting a f2 code on my kenmore elite oasis model 110.67062600 dryer.
  • 3 Answers
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
Posted on Jan 05, 2010
F-2 alarm sounds and I cant turn it off
Posted on Nov 15, 2008
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Have kenmore elite oasis electric dryer model 11068062701 gives us code f, have misplaced manual
Hi and welcome to FixYa, I am Kelly
Your model number appears to be in error: 110.68062701 is what you posted but the manuals are 110.68062800 and 110.68062801.
Parts list:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Dryer-Parts/Model-11068062801/0583/0151200?searchedModel=110.68062&blt=15
The onwers manual is linked off of this page:
http://www.managemylife.com/mmh/owner_manuals/6396/KENMORE-ELITE-Residential-Dryer-
and uses this link:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0801316.pdf (6.44 mb)
The F code is usually followed by another number F1, F2, F20 etc. I can help you but really need to know what the other number is. When the dryer shows an F code it is telling you that there is a failure. Without the number following the "F" there is no way of knowing what that failure is.
If there are any other symptoms can you please post them here?
Thanks for choosing FixYa,
Kelly
May 30, 2011 | Dryers
Kenmore elite model #110-67042601 is flashing a AF code
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
May 20, 2011 | Kenmore 72982 Gas Dryer
I have a model 27096 top load kenmore elite oasis he washing machine that keeps flashing code F2 and keeps turning itself on. Help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Just inherited a kenmore elite oasis dryer model 110 77092600 Where can I get a user manual? Could be online. I called Sears and they want $18 to order one!!! Kenmore charges also.
searspartsdirect.com - and enter your model #.
Jun 22, 2009 | Kenmore Elite Oasis ST 7806 Dryer
Dryers Logo
945 people viewed this question
Top Dryers Experts
