Question about Whirlpool Heating & Cooling
I have a window air conditioner. When it runs for several hours it will trip the breaker. I have had the unit for 5 years. I bought it used and even though it has always shaken when the air compressor comes on it has cooled fine. Recently, however, my landlord changed the circuit breaker (had an electrician come out to do this and supposedly everything is working find). However when I pluuged the unit back into the plug for this circuit, the unit would not even operate for 10 mintues without truipping the breaker. Now the unit is plugged into a different outlet on a different circuit breaker. It has not tripped this breaker for 4-5 hours. However, the whole unit will shake and make noises while it is running. It does still cool. I have not done routine maintaince to clean it except for cleaning the filter. What might be the problem and can it be repaired?
  • nancy_wittum Jul 08, 2010
    I do not know what is causing the problem. My airconditioner (a window unit) makes noise when it cycles and it shakes. It has tripped the breaker occasionally. My landlord installed a new breaker (however, I have reason to believe that he put in a breaker that is not the right amperage for the unit). The unit has been plugged into another outlet on a different circuit and has not tripped the breaker. It is however still making noise and shuddering as it cycles. The only thing I have cleaned on it is the air filter in 5 units. I have heard dirty air conditioners can have problems. What do you think is causing the problem?
    My air conditioner is a window unit. It shakes and makes loud noises when it cycles. I bought it used and I have had it for 5 years. It still cools. My landlord is worried that this is running unsafely. I got two different answers on what could be wrong and need a tie breaker so to speak. Please help ASAP as I have already had a less than civil conversation with my landlord about this.
  • 6,826 Answers
It's probably fine even though it jiggles and makes noise. I would ask the landlord to change the circuit breaker again and ask the electrician what the amps were for the breaker he took out and the one he put in.
Hopefully he did not put a breaker in that was less than the one he took out, but anything is possible.
If the air conditioner works fine on another outlet with a different breaker and hasn't tripped that breaker for a long time, like the 4 to 5 hours that you say, then I would keep operating it on that breaker.
Also, note, that using an extension is not recommended unless it is a very heavy gauge and is rated as an appliance 15A or 20A cord.
The compressor kicking on and off is what is tripping the breaker, as this takes the most amount of current to start (not the fan).
A new air conditioner may not trip your breaker, but the new 5,000 btu air conditioners can cost about $100 or so.
Note: some breaker brands and models are more prone to tripping, so another breaker of even the same Amp rating may still trip with your 5 year old used air conditioner.
Hope this helps! Good luck to you.
Posted on Jul 08, 2010
  • 677 Answers
Hi, The unit rattles loudly when it turns off The compressor in all window air conditioners is a powerful motor. When it starts up - and especially when it shuts off - the whole air conditioner can shake, sometimes loudly. Usually there is nothing that can be done to correct this problem. However, it is possible that the compressor mounting pads and brackets are worn out or missing. If that is the case the pads and brackets can sometimes be ordered and replaced. Be sure that the air conditioner is securely mounted in the window frame if the unit shakes at all. It is possible for the unit to shake free of the frame if not installed properly.
On a second thought you still need to do routine maintenance to clean up AC,for better performance.
Take care.
  • Whirlpool Master
  • 1,711 Answers
The problem seems to be the compressor motor. The compresor of the Ac is actualy an electric motor which is moving the piston. The motor every time is start the starting current is about fives times hiher than the running which is the one after some seconds it have started.
So now the motor which is of some years of working some mechanical moving parts insight have waring out like the ball bearings and the motor need more power in order to rotate therefore more Ampers. The electrical breaker is doing this jop controling how many amper to leave pass throught it like. Now the new breaker is more sensitive or smaller in Amper capacity so it detect the change in ampers and tricker off and this is for your protection, ither the motor will overheat and burn out. The different circuit breaker is ither not so sensitive or on higher ampers that is why it can leave the motor to work for more time until it detect a hevier load on motor which not so frequent.
Now I sugest first to clean the unit from any dust the condesnser and everything this will reuce a litle the power needed.
However if the noice is very loud then I sugest to ask for an estimate for replacing the compressor to solve the problem permanetly. However thisis the most expesive part in the unit and also the replacing of the compressor needs also freon recovery, freon filter and labour and maybe some electrical parts which can rise the cost very high and would be more eficcient to buy a new one insted of repair the old one.
Please bair in mind that old technology AC are cosuming up to five times more electricity that the new technology one so this is one more reason to consider.
  • espressonist
    espressonist Jul 08, 2010
    You have a faulty start capacitor. The capicitor helps start the motor ... since it is not doing its job, the motor draws LOTS more power from the line popping the breaker. Have your professional RV service center service your AC
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Aug 25, 2010 | Coleman Mach III Air Conditioner
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
Air conditioner runs for several minutes then
Take it back to the dealer and have them fix it, could be a compressor froze up or a fan froze up. If you disconnect the compressor and turn it on and it trips the breaker the fan is probably
bad. If you disconnect the Fan and turn it on and it trips the breaker
it is you compressor.
Jul 16, 2010 | Dometic Rooftop RV Air Conditioner
Breaker keeps tripping after several hours of runtime. System has 40 amp breaker & is only drawing 31 amps.
electric motors (when they start to break-down) will run normally for hours (and read amps within the tolerance level).
Then after a long run time - the amps will 'spike' and trip the breaker.
This is a fairly common occurance - although there are other things that can cause a similar problem (though less likely), i.e. a dirty condenser coil, an improperly charged unit - or a bad breaker.
Bottom line. I think you need a Service Tech to take a look at the AC.
hope this helps
Jun 06, 2010 | Haier HC48C1VAR Central Air Conditioner
Air conditioner is tripping after one hour
clean filter and Evap coil and condensing coil. also some units have a gfi breaker at the plug witch some times go bad
Apr 08, 2010 | Samsung AW1203B Air Conditioner
Breaker trips on condenser unit on heat pump after several hours of operation
Hi, check amps on unit, and make sure breaker matches, check unit voltage tag, it will tell you what size breaker you need, or may be breaker is loosing resistance, replace breaker, if problem continues, a/c maybe over working because of high temp, temp. affect amperages, and that would be normal, if it trips after few hrs. also check a/c for lack of freon, sometimes, they need a tap up of refrigerant, not enough freon and they would run longer, get hotter and eventual trips. breaker doing his job. good luck
Aug 03, 2009 | Amana PTH123B25AJ Heat Pump Air...
Air conditions trips circuit, wont stay running.
Is it a window unit?
Did you check that the condensor coil is free of dirt?
Is the Fan motor running or does it stop before the breaker blows?
Jul 29, 2009 | Kenmore 75085 Air Conditioner
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
100 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
