Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Roller bar does not spin
How do I access the belt? the roller bar does not seem to spin
  • 3 more comments
  • Anonymous Apr 22, 2008
    Power bar does not spin. Smells like something is burning. Can't open it up to check belt.
  • Anonymous May 14, 2008
    get to belt
  • Anonymous May 16, 2008
  • mariovilas May 28, 2008
    The roller bar doesn't spin, but I open it and the belt isn't broken, and the light doesn't turn on....but the vacuum is still working and vacuum when on the floor setting...looks like the power doesn't get "juice".
  • Anonymous Nov 20, 2008
    How do you get the unit apart to check the roller bar belt
I have the same problem
Posted on Nov 11, 2008
It has a restart button that fixed the problem - I took it to a repair shop and they solved it.
Posted on Apr 19, 2008
Kirby vacuum-The beater bar is turning, but the light is not on. Is something else wrong?
Check to make sure the magnet on the roller is on the side with the coil (this activates the light). You may have installed the roller with the wrong ends in the opposite sides.
Apr 11, 2014 | Kirby Vacuums
Belt spins, roller does not
The belt has probably lost elasticity or the clutch needs adjusted or a new rubber pad.
Feb 11, 2014 | Riccar 8850 Vacuum
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
Roller brush does not engage, don't know how to access belt. Brush does spin freely.
flip the vacuum over for you can see the beater bar, remove all the screws in that bottom housing that are countersunkunk.Seperate the housing and see if belt is broke/stretched and very that the motor turns
Jan 20, 2011 | Eureka 3041BZ Upright Vacuum
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
The power bar stopped working. The vaccume is
If its 2 months old I wouldnt stress looking at anything. Box it up and take it back. Something that flimsy doesnt make sense to keep does it?
Apr 29, 2010 | Hoover S3765-040 WindTunnel Bagless...
Roller bar does not spin when turned on my DC14
Either your belt is broken or the roller is not functioning dues to debris or hair or bad bearings. You'll have to take a look at the bottom of the vacuum and see if the belt is broken. If it isn't, you need to remove the roller bar and see if there is anything keeping it from spinning. If the bearings are frozen, you can spray them with a lubricant and try to free them up. If this fails, then you will need to get a new roller. Hope this helps. Good luck!
Mar 10, 2010 | Dyson DC14 All floors Bagless Upright...
There is power but the motor seems to not turn, therefore, there is no movement via the rollers. please help
The belt which turns the roller brush is probably worn and therefore not turning the roller brush. You can get a replacement here:
Filter Queen Majestic Replacement Belt
Nov 05, 2009 | Filter Queen Majestic Canister Vacuum
My vacuum has not been running right..the beater bar is not picking up and the rollers aren't spinning...the belt doesn't need replaced so what else could it be...everything else seems to be running...
The motor shaft that spins the belt may have hair wrapped arount it, causin the belt to slip. You can't miss the burnt odor.
Remove the belt and clean the motor shaft.
Sep 29, 2009 | Vacuums
No suction in floor attachment *& brush not turning
Lay the machine on the floor with the front side down. Undo the 3 large plastic screws with a coin of some sort, then remove bottom panel. On the back of carrage where the roller bar sits their should be a clear plastic tube check this tube is free of dirt. Check around inside the carrage for hair string etc. Check belt for breaks and swelling in the rubber pull ont roller bar and check the end caps on the roller can spin freely. If not pull off the end caps these will be very tight and wash out all dirt and fluff, dry thourley and lubricate centre pin and end caps inside the roller with baby oil or wd-40. replace roller bar and belt, turn roller bar twice slowly to centralise the belt, replace bottom panel making sure that the clips on front are sitting in their holes. fastern the plastic screws and leave two hours before usage
Oct 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
