Question about Brother HL-5240 Laser Printer
5240 brother i have 5240 the problems is that i have all lights blinking all the time i checked,there is no paper jam inside the printer,toner is o.k,drum is o.k i changed also fuser module nothing,still all ligts blinking i need sugestion,mybe i need to change laser? if someone know what to do,please help thanks allot elvis
  • Anonymous Jul 22, 2008
    Tried the solution listed but it did not print anything and tried installing a BrotherBR_DEVELOP printer to my system.
I just solved my similar problem- switch off printer, open front door, hold down go (blue) button. Now switch on, holding the go button for about 10 seconds then closing the door.This left the lights all off, green light only when pressing go. Switch off then on, it worked! hopefully this helps someone else. Ross
Posted on Apr 13, 2009
-Turn Power Off
-Open Front Cover
-Hold down "Go" and "Job Cancel" Buttons while turning on Printer (All lights will stay on)
-Press "Go" button 2x
-Press "Go" button 5x
-Close door and Print
Posted on May 22, 2008
My brother HL-5240 toner light blinks , what is the problem ?
You need to change the Toner Module, it is.has run out of Toner, that's used to print out.
Oct 11, 2011 | Brother HL-5240 Laser Printer
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Oct 02, 2010 | Brother HL 1250 Laser Printer
Every light is blinking, toner, drum, paper and status light
a would advise you service the printer...... sometimes dirt and other things can cause it to malfunction
May 25, 2010 | Brother HL-5240 Laser Printer
Paper jam in printer. Error light blinking.Can't get paper out
Turn the printer off, Open the front cover where the drum and toner are installed. Remove the drum and toner (cartridge). look inside the machine for a paper jam, also open the back cover and check there.
Apr 23, 2010 | Brother HL-2170W Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
Paper light keeps blinking and won't print I have paper and it's set as default printer
It keeps blinking because there is a paper jam. Open the front cover and take out the toner/drum and see any jammed paper. Also, you can open the back cover, pull the paper guide down to see the rollers.
If the above does not work, take off the front cover. Pull the tabs on the side. Pull out the toner/cartridge. Look for a blue tab on the top, and you need to slide that from right to left. Put everything back and see if this solves the problem.
Sep 30, 2009 | Brother HL-2040 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Printer problem
hi, Take out the toner and check for a paper jam.turn the printer upside down and check under the paper tray for a jam. When you reset the printer check to see if the printer picks up the paper, if it tries to pick up the paper then the red light flashes you should rough up the roller on the front above the paper tray, the rollers sometimes get smooth and won't pick paper up. You should also look inside where the toner cartridge goes and there are some little plastic flaps.Check that these are not stopping the paper going it. hope this helps
Sep 25, 2007 | Brother HL-2040 Laser Printer
Brother HL-5240 Laser Printer Logo
802 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
