Question about Vacuums
THE BELT DRIVE HAS WORN INTO THE PLASTIC CASE TO THE POINT THAT IT RUBBED ON THE IMPELLER AND BROKE IT , WHAT CAN BE DONE TO REPAIR THIS
    President:
  • 1,673 Answers
You would have to replace the bad parts along with the belt. But you did not give brand and model number info, so can't help more with that info.
Posted on Apr 20, 2008
I cleaned the brush head to my Dyson 24 and all was well but now the brush roller does not spin. Have pushed reset button several times. Can feel it vibrate but not engage.
The belt and clutch are probably worn or broken. Instead of a normal brush roller belt like most vacuums have, Dyson designed these with a plastic clutch between the motor and brush roller, so you can turn the brush off for hard surfaces. The belt from the motor to the clutch is replaceable, but it is the belt least likely to wear out or break. The belt to the brush roller, which is the one that takes all the beating and encounters all the dirt and grit is plastic welded into the clutch and cannot be replaced. You have to replace the entire clutch when that belt goes. On a normal vacuum, this is a $3.00 to $5.00 repair. On a Dyson, the part is around $25.00 retail, and you have to tear half the vacuum apart to get to it. You don't need much in the way of tools to repair it, as most of the vacuum simply snaps together, although you have to take care that you don't break the plastic parts getting them apart. You do need a torx screwdriver to remove the clutch housing. I've done two of these in the last week, both with the same issue.
Jan 07, 2017 | Dyson Ball DC24 Bagless Upright Vacuum
Why does it emit a high-pitched squeal (while running)?
This is usually caused by a belt being too tight or the wrong size. It can also be caused by something wrapped around the brush (like loose thread from a rug or yarn, shoestring etc. Try inspecting the brush and belt.
Dec 07, 2015 | Hoover UH70120 WindTunnel TSeries Rewind...
I have a Kenmore vacuum cleaner 116.35922 and it's making a loud noise and not picking up dirt. I checked the hose for a clog and changed the bag. What else can I do?
Check to see if the brush is spinning when the unit is running. If not, the drive belt may have broken and will need to be replaced. Common sized replacement belts can be purchased at most department stores. Kenmore belts should be available at most Sears stores.
Another possibility is that if a large enough object was picked up, it may be lodged in the impeller, or impeller housing. If so the housing will need to be disassembled to determine if any physical damage was done, and to clear the debris.
Feb 24, 2011 | Vacuums
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The belt keeps breaking lately. I've had the
Before putting on the new belt make sure the brush turns freely and nothing is wraped around the bearing ends, if it is not turning free and is clean try a little grease or vasaline on the bearing ends. dont get any on the belt though. check the motor shaft also it should be clean and no residue from the old belts on it. it can be cleaned with rubbing alcohol and a rag, if really caked try a scotch pad .
Oct 24, 2009 | Kenmore Vacuums
Belt and lifter getting hot right away on start up.
I would say that it is definitely running backwards. I have a guide to replacing the power switch that outlines the reassembly of the Kirby and tells you which carbon brush wire plugs into which hole on the power switch. Each carbon brush has a letter (B or O) and the same two letters are on the switch to help you get the wires back on right. (the "B" attaches to the "B" and the "O" attaches to the "O") Here is the link to the guide and I hope it helps,...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Marci
Jun 19, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Eureka 5843 belt keeps slipping off of drive spindle.
Tough one. Typically the only 2 things that the belt contacts is the motor drive spindle and the brush roller. Anything else would only be there to protect the belt from debris. Can you turn the brush by hand and see why the belt is coming off? Is the spindle wobbly? If so, you may need another motor as I don't think it is easy to get parts for the motor. Hope this helps and good luck!
Mar 22, 2009 | Eureka Whirlwind LiteSpeed 5843 Upright...
Hoover U4395 Vacuum fan (impeller) broke
this is a left handed thread
you mite have to hold the other end of the shaft twith a pair of pliers , to un screw it
Feb 06, 2009 | Hoover Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
