Question about E-Machines eMachines Monitor E15T4
Frequency out of range
"frequency out of range" message appears after black screen during game. have a ATI Radeon x1300 and Emachine CRT monitor Eview 17f3. I have lowered my resolution in the settings, but still error msg.
    President:
  • 1,768 Answers
The monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Posted on Jul 08, 2010
My emachine will not come on-just makes beeping sounds every few sec. is it my hard drive
When you here a beeps during turn on that is a RAM problem. So you need to check the RAM remove it first and clean the dust. Use also the other memory slot
Please pull out the memory and clean the silver coating pins with a rubber eraser to clean dust and stains that causes disconnection.
Apr 02, 2010 | E-Machines eView 17f3 17" Flat CRT Monitor
I have no picture on the screen and the blue power button just sits there blinking very quickly.
remove the ram and then clean the ram and then insert it again into the ram slot then power on your PC then you will see your moniter working.
Oct 08, 2009 | E-Machines eView 17f3 17" Flat CRT Monitor
I cant play nba 2K9! when i launch the game my monitor becomes black!
It goes black because the monitor you are using does not support the resolution you are trying to force through it from the video card. Start at 1024 X 768, if the screen shows on the monitor than that is a good start. If it doesn't then I would suggest getting on the manufacturer's web site and downloading the latest drivers. I'm pretty sure you are dealing with a driver issue.
Sep 06, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Try to set the monitor refresh rate to Adapter Default despite of Optimal or lower rate of refresh. For this first download the manual of your monitor and check what is the highest refresh rate your monitor can suport. Then goto the display properties and set the adapter refresh rate to Adapter Default. In most cases such problem is solved. You did not mentioned the OS. This method is applicable in Windows only. (ehteshamhusain@gmail.com)
Jul 23, 2009 | HP Compaq FS7600 17" CRT Monitor
Low brightness on second monitor using Radeon X1300 video adapter
According to the X1300 specifications here it does support multiple displays. The option to configure the display is found in the Catalyst application. Do you have the latest version of that? You can get it from their website.
Jun 01, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
The screen flickers into hour-glass figure.
It's the tube going out. You need to replace it. If you want to stay with CRT monitors, you should be able to pickup a used one for around $10.00 on Craigslist.
http://www.craigslist.org/about/sites
Nov 24, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
S video out
To my thinking, your concern would largely be dependent on the Screen Resolution setting of the PC. It may be that the screen resolution be initially lowered down to the lowest possible.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Unlocked e-machines 17f3
It depends on the monitor, but try holding the Menu and Right arrow button together.
Aug 07, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
E-Machines eMachines Monitor E15T4 Logo
479 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
