Due to high voltage spark occur in my tv and then there is no power light in the tv model bpl djr-21
  • 532 Answers
Hi
Open the TV at the back with a screw driver, then go and check the the fuse if it has not cut. the fuse is like bulb with thin wire. If it has cut, you will have to replace it it is very cheap to buy. check the # on it to know the right fuse that you will buy when you get to the store.
If there is nothing wrong in the fuse, then, the transformer is faulty.
Use a multimeter to check if the transformer is reading, if not replace it.
Thanks.
Posted on Jul 08, 2010
Bpl tv fcr 21
Check and replace its main system memory IC. It is faulty.
May 12, 2013 | Televison & Video
Sound is not comming out of my bpl tv ftr21
Can anyone help... I have BPL cv 21 model sp 2B. I have problem. By mistake my repairer have open data manu, and try to slow audio, by doing these he dont know which button he press.. now audio has gone, and auto setting is also not working
Jul 11, 2012 | Televison & Video
I have BPL 21 Studioline 1000W, problem is suddenly the picture is becoming a thin Horizontal line at center, sound is perfect, when i beat with hand behind the TV picture is back to normal state, picture...
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
The fault is the FAILURE OF THE SOLDER IN THE VERTICAL IC OF THE TV.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Jul 25, 2011 | Televison & Video
After turning on, my tv (21 inch CRT) produces peculiar rattling noise like high voltage sparking. The screen remains blank and there is no audio.
particularly that is a sign of leaking of high voltage in the secondary power supply or flyback transformer and should be corrected right away..check for emission of odor smell of ozone which is coming from high voltage leaks to make sure that it is definitely a high voltage leak...
Jul 18, 2011 | Televison & Video
I have a Hitachi Tv Model # 5oux14bc I can hear clicking sound when i turn the power button and sometimes the red light will come on and then go off What can be the problem>
The clicking sound you are hearing is due to the relays turning off the set because a protection fault has occured(usually over voltage due to failed voltage regulators). A component level repair is possible more often than not but if you want to do it yourself then you should know how to use a multimeter and soldering gun.
PS: It is not a good idea to mess with High Voltage appliances unless you are highly skilled in electronics . The set holds lethal voltages for several days after its turned off and unplugged(the voltages are present in the capacitors). Your life and limb are worth much more than this.
Oct 30, 2010 | Televison & Video
Due to high voltage my Onida Television got
the power supply filter condensor got leaky in ur tv,,,,,
well it will cost 80 rs... the picture will wave ,, call a tech person to change it. value of condensor 150mfd 450v
Mar 23, 2010 | Televison & Video
BPL TV MODEL FQR 21 don't start due to moisture
i have a cpu but my monitor has been broken so i wanted to connect my Bpl feb 21 tv can i?
Sep 09, 2009 | Televison & Video
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
