I want to know how to configure my samsung 00062d with my tv
Samsung tv ln32d450g1 the menu does not show any option to configure network settings
That is my problem here are the menu options I have
picture mode
sound mode
antenna
plug and play
e-manua
within each option there are subtitles but nothing that refers to network
Nov 10, 2016 | Samsung Televison & Video
Samsung TV loss of signal. Our Samsung tv has lost all free to air channels.
try setting the right IP configurations if that is the error reported
May 16, 2016 | Samsung Televison & Video
No codes on the remote control to configure the self focus
Codes for Samsung are: 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Sep 18, 2012 | Televison & Video
I need to configure the settings on my Samsung TX-R2035 TV so i can play my Xbox 360 on it. I don't know what all these abbreviations are, though. Help?
If you use the yellow, red, white jacks, these are called RCA jacks.
The tv should have these. Some have two sets of these. Make sure yours are hooked up to input or a/v So run xbox cords to tv input or a/v jacks.
Then turn on your tv and turn it to input or a/v channel
Some tv remotes have an input button on them
If you have any other questions just ask.
May 16, 2011 | Samsung DynaFlat TX-R2035 TV
My TV is only 480i. When my receiver reboots, I cannot see the settings menu to configure the receiver to output to 480i. I need to know the remote keystrokes to press to configure the receiver for...
You did not give your model number of receiver. Some of the ones from 2007 or so have a switch on the back for video resolution, 480i, 480p 720p 1080i so set this switch to 480i.
Mar 08, 2011 | Samsung HDTV Digital Terrestrial Receiver
Settings
Have to reset or it is reset to factory settings?
Has anyone been playing with this TV, i.e. repairing it, replacing boards etc?
I believe - do not know it for a fact - that Samsung has this protection in palce which identifies the boards in a TV and once you switch a board the TV needs to go through a service re-administration to remember its current configuration.
There's no explanation of why would a TV need to do that other than to restrict users to Samsung service centers only.
Again I do not know this for a fact, but I have seen other Samsung TVs that do exactly the same and they start doing it upon replacing boards on them. It's a simple logic.
Nov 04, 2009 | Samsung LN32A330 32 in. LCD TV
P4 motherboard power pin configuration
Order you a schematic online for your TV.Cost $45.00 and some cost as much as $150.00
Feb 17, 2009 | Samsung HCL4715W 47" Rear Projection...
How do I determine my tv's configuration.
You can get configuration from the link below
http://www.mediacollege.com/equipment/samsung/tv/hc/hcn529w.html
Jan 30, 2009 | Samsung HCN529W 52" Rear Projection...
Samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
Nov 29, 2008 | Samsung LCD PREVIEW MONITOR f/950 AND...
Televison & Video Logo
Top Televison & Video Experts
